Where to send my T3 turbo
Old Jul 26, 2008 | 01:41 PM
denbo's Avatar
denbo
Default Where to send my T3 turbo
Yeah i need to send my T3 away for rebuild where is the place to send it to and what costs am i looking at to get it done ?
Cheers denbo
Old Jul 26, 2008 | 01:54 PM
GaryHurn's Avatar
GaryHurn
cr turbos or midland turbos, turbo dynamics, turbo technics, universal turbos, turbocentre!!!! lots of choice
Old Jul 26, 2008 | 07:14 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
i recommend the turbo centre, had mine rebuilt to stg1 T34 spec for £575 inc vat, was very happy with the service
number is 01924 404115 if you want it
Old Jul 30, 2008 | 08:43 PM
denbo's Avatar
denbo
Got one today from turbo technics and am well happy !!
Old Jul 30, 2008 | 08:47 PM
mad dog younge's Avatar
mad dog younge
denbo turbo technics are not that good mate .ive heard bad shit about them
Old Jul 30, 2008 | 08:57 PM
denbo's Avatar
denbo
What like Younge ?
Old Jul 31, 2008 | 03:53 PM
Moonie's Avatar
Moonie
Never had a problem with TT myself.
Old Aug 1, 2008 | 08:27 PM
denbo's Avatar
denbo
Old Aug 16, 2008 | 01:57 PM
denbo's Avatar
denbo
I fitted the new turbo today and the car is a bit better will i need to get the car set-up again ?
Old Aug 16, 2008 | 04:11 PM
Shep_Cobain's Avatar
Shep_Cobain
Not sure, but did you buy it outright or send it to?
Do they have a site Denbo or did you phone em? How much was it as i need to send mine off.
Old Aug 16, 2008 | 04:49 PM
TURBOCENTRE is 01924 404112, not as above, ask for Andy or Craig.
Old Aug 16, 2008 | 05:12 PM
LHD220Turbo's Avatar
LHD220Turbo
if the turbo is the same spec as your previous one, then there is no need for a new set up if the spec has not changed
Old Aug 16, 2008 | 05:31 PM
denbo's Avatar
denbo
LHD220TURBO-Cheers mate i think i need a new clutch now aswell
SHEP-COBAIN-£350+vat std turbo !
Old Aug 16, 2008 | 05:40 PM
LHD220Turbo
standard clutches are quite cheap; i think i have a new one in my shed somewhere, also make sure you change the clutch cable as well
clutch cables will be no more than £15 and piss easy to do
Old Aug 16, 2008 | 05:54 PM
denbo's Avatar
denbo
Well i have put a 2nd clutch in with recon gearbox just befor xmas and the car was ok but the last few weeks its not the same , i think i will get a fast road clutch next
Old Aug 16, 2008 | 05:57 PM
LHD220Turbo
to be honest the stabdard clutch will cope with 330bhp if its in good nic; i know of a few stage 3 saff's running standard clutches
you're better of sticking with a standard one or go the whole hog and get an AP or Alcon 6 paddle clutch, that way if you dont want big power late on you wont have to do the clutch
whatever you do; do not buy a clutch off a guy on ebay called techni clutch
Old Aug 16, 2008 | 06:02 PM
denbo's Avatar
denbo
So then a standard clutch it is fella allso i have put a new standard cam set in aswell don't know what piston's i have tho !
Old Aug 16, 2008 | 06:08 PM
LHD220Turbo
did you change the cams for a reason?
only do things that need doing mate; otherwise you'll spend a fortune!
Old Aug 16, 2008 | 06:40 PM
Shep_Cobain
I take it you sent your old one to them yeh?
Old Aug 16, 2008 | 09:05 PM
denbo's Avatar
denbo
Yes i did matey
Old Aug 17, 2008 | 01:24 AM
rst deany's Avatar
rst deany
Unhappy
Think it is a rs turbo not a saff,
Old Aug 17, 2008 | 12:48 PM
denbo's Avatar
denbo
Just been for a spin in the car and i think somit is up like , reason been is that it use to hit 1 bar and now its hit 0.2 and holds their ready for a gear change and u can just hear the DV ?
Old Aug 17, 2008 | 01:56 PM
Miller 3's Avatar
Miller 3
check the actuator as this is now probably different than before
Old Aug 17, 2008 | 02:30 PM
denbo's Avatar
denbo
Got new one with the turbo unit but don't know which one thats on it
So u think its the actuator ?
Old Aug 17, 2008 | 05:12 PM
LHD220Turbo
is it an rs turbo?
you will have to set the actuator up of course! the company supplying the turbo are not going to know what PSI you want to run.
what boost does your spec allow? - you need to set the actuator to your spec
Old Aug 17, 2008 | 05:38 PM
Miller 3's Avatar
Miller 3
Remember to ONLY turn the end that is on the waistgate and NOT the rod going in to the actuator.
Old Aug 17, 2008 | 06:29 PM
denbo's Avatar
denbo
14 psi the car is set at lads so what do i need to do then ?
Old Aug 17, 2008 | 06:41 PM
Miller 3's Avatar
Miller 3
Are you running any form of boost control?... If not just turn the adjusting part of the actuator clockwise till you get your 14psi but only do what i said above
Old Aug 17, 2008 | 07:00 PM
LHD220Turbo
as miller says
each turn equates to approx 1 psi; but dont go mad; do maybe 5 turns, then road test. Keep doing this until you get 14psi
set it up using your boost gauge; 1 bar is approx 15 psi
basically the shorter the rod; the more boost
Old Aug 17, 2008 | 07:10 PM
Miller 3's Avatar
Miller 3
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
