stupid me
hi guys,i have done something very silly and wondered if you could help,here goes
whilst removing the cylinder head on my bt escos i have accidentley dropped the torque bit down the hole which is at the back of the head, on removal of the head i discovered or assume it has fallen all the way down the hole to the back left of the block (the slightly larger one next to the two square water ways) what is this hole and/or where will the torque bit be found and whats the best way to do this cheers guys. any help appreciated as i want to be ready for ford fair
Think the port your describing is the main oil return to the sump, you may have to remove the sump to get the torque bit back.
Have you tried putting a telescopic magnet into the sump through the turbo oil drain hole? Chances are the torque bit has moved in the sump, try going into the sump through any hole you can and fishing around with the magnet to see if you can find it.
trouble is a magnetic pick up pen sticks to everything metal inside.
I think your quickest solution is to have the sump off mate.
last year on my last day b4 we left for x-mass i was doing a head gasket and timing belt at work on a zetec focus and my boss was rushing me becose he wanted to no weather it would start b4 we left so i accidently left the timing pin screwed into the back of the block (the one that locks the crank) and it snaped it when i terned it over my boss said it would be ok and you no wot it was lol and a year later when it come back for a service it was stuck the the drain plug lol
in my opinion its gonna sit at the bottom of the sump and wont cause you any problems the forces of gravity are quite strong
hope this helps
hope this helps
if its the same as a 2wd i would leave it as i did the same tried to get it with a magnet and got that stuck as well, after a lot of hard work and weeks later i bit the bullet and left it down there brought a new one and put it all back toghether and it was fine and has been ever since.
Adam Graham
Sep 6, 2015 06:04 AM
Sierrasideways
15
Aug 31, 2015 10:10 AM
