Koni Adjustables Question on 4x4 Cossie
Old Jul 23, 2008 | 01:05 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default Koni Adjustables Question on 4x4 Cossie
Hi all. Im getting my car today or tomorrow from the garage after having new cv joints and boots at the front as the angle of the driveshaft is too steep for them. My car is lowered on -25mm konis adjustables
My koni adjustables are on the hardest setting. The old owner had this set up that way.
Anyway I was told if I loosen them up it will raise the car slightly, creating less of an angle on the shafts.
Will this work?
And how many turns with the key supplied with the kit do I need to turn it till it is on the loosesed setting, as I was told if I turn it for ages the top bit will fly out.
Many thanks all.
Old Jul 23, 2008 | 02:38 PM
KSA-Cossie's Avatar
KSA-Cossie
They're not height adjustable m8.
Old Jul 23, 2008 | 02:40 PM
kosienutter
oh not at all? i thought the bit u tighten up or lossen off, screws a rod inside the absorber and if you tighten it compresses the spring ever so slightly. cool cheers for the reply m8
Old Jul 23, 2008 | 02:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Nah just stiffens up the shock.
Old Jul 23, 2008 | 10:51 PM
dazzle740's Avatar
dazzle740
a -25mm drop should be ok mate have you tried to see if your engine mounts are knackered as if so when you accelerate the engine will rock and either pull out the shaft or strain the cv joint at that point
Old Jul 23, 2008 | 10:52 PM
dazzle740's Avatar
dazzle740
But as said above the koni are not height adjustable in any way the adjuster at the top just stiffens or softens the internal dampers
Old Jul 24, 2008 | 01:05 AM
kosienutter
i had the mounts checked and they were fine. many thanks though. will be softening them up anyway as the ride is too harsh at the front anyway.
chow for now
Old Jul 24, 2008 | 04:51 PM
benporter's Avatar
benporter
do a search for adjustable konis, thers been some interesting stuff about having them to soft been posted recenty
DixieTheKid
Jul 23, 2023 10:16 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
Caddyshack
Aug 19, 2015 07:29 PM
dal3door
Aug 13, 2015 06:55 AM
