mfi erst wont run.....
Old Jul 22, 2008 | 11:01 PM
boothy's Avatar
boothy
Default mfi erst wont run.....
right built engine back up,,getting fuel to the fuel filter then to the metering unit, and to the cold start pipe, but no fuel out of the other 4 pipes that feed the injectors, any help please, the metering unit was workin before
Old Jul 22, 2008 | 11:05 PM
nickscunny's Avatar
nickscunny
Have you checked the washers are there that go on the metering head that the injection pipes go to?
Old Jul 22, 2008 | 11:06 PM
boothy's Avatar
boothy
are they the copper ones that are on the bolts?
Old Jul 22, 2008 | 11:09 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
yep
Old Jul 22, 2008 | 11:13 PM
boothy's Avatar
boothy
yes they are all on pretty suremy mate did it he knows his stuff but this one baffled him any ideas??
Old Jul 22, 2008 | 11:21 PM
nickscunny's Avatar
nickscunny
erm.... injectors all ok?
I have just put an rs turbo in my cab and i went through all this palarva with mine......
Turned out it just needed new plugs, leads, dizzy, rotor arm and struck her up and she ran..
If it werent for a mate suggesting it then i would be still ragging fuel lines to pieces and god knows....
Have you had injectors out and turned the car over so the injectors spray out?
Old Jul 22, 2008 | 11:29 PM
boothy's Avatar
boothy
sure they are ok took the pipes off the top of the metering unit and there aint any fuel cuming out,so not even getting to the injectors mate,,,
Old Jul 22, 2008 | 11:41 PM
stevenebm's Avatar
stevenebm
post whore
had this before when it was turning over but not firing up.fuel there etc.in the end had to jump start the car and it was fine after that.god knows what it was.
Old Jul 22, 2008 | 11:49 PM
boothy's Avatar
boothy
ill try that mate hopefully works,so you have hadthe same problem mate?
Old Jul 22, 2008 | 11:53 PM
stevenebm's Avatar
stevenebm
post whore
yeh mate couldnt understand it.tried different metering heads etc and it didnt work.just got ma mate to tow the car and first bump and away it went.was fine after that.weird.
Old Jul 22, 2008 | 11:56 PM
boothy's Avatar
boothy
hopefully mate, bit of a pain gotta bleed brakes put drive shafts it new clutch cable few other bits
Old Jul 23, 2008 | 12:17 AM
stevenebm's Avatar
stevenebm
post whore
yeh a know its so depressing when they wont go.makes you lose heart but gota look forward till when it fires up.fingers crossed for you mate.
Old Jul 23, 2008 | 12:34 AM
boothy's Avatar
boothy
cheers mate,,,
Old Jul 23, 2008 | 07:26 AM
boothy's Avatar
boothy
anyone els have any ideas?? please,,,
Old Jul 23, 2008 | 09:37 AM
NATH-RSZT's Avatar
NATH-RSZT
as said on your thread make sure boost pipes are on.
Also as said above a tow start may be needed. i had a full tank and was jump starting it for ages but nothing. got a mate to tow start me and it fired up.
steve.rst
Mar 15, 2016 08:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
beller
Sep 21, 2015 04:13 AM
stevierob
Sep 7, 2015 07:09 PM
