Black top zetec alternator bracket help
Old Jul 22, 2008 | 10:35 AM
siward's Avatar
siward
Default Black top zetec alternator bracket help
Hi all,
Does anyone know if the setup in the pic below will fit a 2.0 blacktop zetec engine and what belt would i need? Also would the zetec alternator fit onto the cvh bracket or would i need to use a cvh alternator and swap the pullys?
Any help would be apriciated.
Thanks
Si
Old Jul 22, 2008 | 04:05 PM
crazycage's Avatar
crazycage
Originally Posted by siward
Hi all,
Thanks
Si
yes but you need to cut a notch out of it or it will hit the water pump if you hold it up to the front of the block you will see where it needs cutting i run mine like that.
Old Jul 22, 2008 | 04:49 PM
siward's Avatar
siward
Thank you.
Si
Old Oct 10, 2010 | 01:25 PM
12_Second_rst's Avatar
12_Second_rst
anybody know what this brackets off and where i can get 1?
robnock
21
May 13, 2019 05:29 PM
Porplus12
Sep 10, 2015 07:20 PM
robnock
Aug 22, 2015 10:51 AM
gingerturbo
Aug 11, 2015 09:44 PM
turbobill
Aug 1, 2015 08:55 PM
