T5 Gearbox
Old Jul 21, 2008 | 10:08 AM
Dearo's Avatar
Dearo
Default T5 Gearbox
The Input Shaft Bearing needs replacing on my T5 gearbox, can you suggest someone or a company to carry out the repair ??
I live near Basingstoke in Hampshire.
Dearo
Old Jul 21, 2008 | 11:52 AM
LHD220Turbo's Avatar
LHD220Turbo
do it yourself if your half handy with a spanner; the bearing will cost between 15-20.
a garage will charge you an arm and a leg to remove a box and refit, its all labour basically - input shaft bearing are fairly easy to do, i done one 2 weekends ago
i can give you a few pointers if need be
Old Jul 21, 2008 | 02:32 PM
Dearo's Avatar
Dearo
Hi Mate,
Yeah I will remove the box myself, but according to the Ford T5 Manual I need a special tool to fit the new bearing ??
Is this correct ??
Dearo
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
