who does big wing sumps
Old Jul 20, 2008 | 07:49 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default who does big wing sumps
dont mind sending mine to them just wondered who done them and what sort of dollar?
Old Jul 20, 2008 | 08:10 PM
AlexF's Avatar
AlexF
bug wing
Old Jul 20, 2008 | 08:15 PM
Roosie's Avatar
Roosie
new type of sump lol
Old Jul 20, 2008 | 08:22 PM
Nash's Avatar
Nash
Cake lover!
Roosie easy to change the Titttttttttle just click next to the heading when in the main menu.
Rainbird does big wings and so does Reyland.
Old Jul 20, 2008 | 08:24 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Failing that Marco does BIG wing sumps too I think.
Old Jul 20, 2008 | 08:25 PM
s-line's Avatar
s-line
Default big wing sump
i believe pete off here, ashfield motorsports does these!! not 100% sure tho!
Old Jul 21, 2008 | 11:34 AM
rickslack's Avatar
rickslack
NMS do some very nice ones.
Old Jul 21, 2008 | 12:49 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Originally Posted by Nash
Roosie easy to change the Tittle just click next to the heading when in the main menu.
Maybe he doesn't know what the Tittle is?
Old Jul 21, 2008 | 01:03 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Garage19 did mine, cant remember exact price but was under 100 quid.
Old Jul 21, 2008 | 03:29 PM
Char1ie's Avatar
Char1ie
I had an issue with oil starvation at Snetterton this weekend under heavy braking and was thinking about a bigger sump. Does anybody know a good source for a big sump with baffles, or do the ones listed above come with internal modifications to stop oil surge already?
Cheers,
Charlie
Old Jul 21, 2008 | 05:33 PM
Kelv's Avatar
Kelv
Almost there!
2wd or 4x4?
Old Jul 21, 2008 | 06:48 PM
BLACKCOS's Avatar
BLACKCOS
thats wat killed my last engine oil starvation because i never had a big winged baffled sump on
Old Jul 21, 2008 | 08:29 PM
totalbhp's Avatar
totalbhp
SCS in peterborough make the big wing sumps give them a call 01733 576614
Old Jul 23, 2008 | 05:40 PM
marco polo's Avatar
marco polo
hi mate
this is one of the best out there
cheers marco
Old Jul 23, 2008 | 06:17 PM
Roosie's Avatar
Roosie
who done that
Old Jul 23, 2008 | 06:45 PM
marco polo's Avatar
marco polo
my mate
they are the bollox mate gated/baffeld +they hold 7 litres of oil
Old Jul 23, 2008 | 06:57 PM
xr4x4rs's Avatar
xr4x4rs
whats the price of these mate and does he do 4wd ones
Old Jul 23, 2008 | 06:59 PM
J1mbo's Avatar
J1mbo
B1mbo
scs sumps are very very good quality and do 2wd and 4x4
marco polo's Avatar
marco polo
no mate he wont do them for the 4wd
Old Jul 23, 2008 | 07:00 PM
marco polo's Avatar
marco polo
these are the same that rsjp uses
Old Jul 23, 2008 | 07:03 PM
cossie604's Avatar
cossie604
...how much roughly then chap?
Old Jul 23, 2008 | 07:33 PM
Char1ie's Avatar
Char1ie
Think they're around 300. Looks like the most professional solution. Is there anyone that adds or has added baffles to a 2WD sump? Not sure about the need for extra capacity but baffles are a must.
Cheers,
Charlie
Old Jul 23, 2008 | 07:43 PM
Miller 3's Avatar
Miller 3
That looks the nuts marco
Old Jul 23, 2008 | 08:38 PM
Garage19's Avatar
Garage19
They do look nice but there are a couple of issues with that sump that have been bugging me...
1) The right hand wing where it curves up, there is no point. It wwill not gain you any capacity as it will not fill up, you will just trap air.
2) This is only a minor one. Why go to the trouble of plating it and then having to pass that extra cost onto the customer when it is pointless. Its emersed in oil. Its never going to rust!
Other than that, nicely made.
Old Jul 23, 2008 | 09:33 PM
marco polo's Avatar
marco polo
they are 300 and you supply sump and oil pick up pipe of your choice either 4wd or 2wd what ever oil pump you want to use
marco
Old Jul 23, 2008 | 09:46 PM
marco polo's Avatar
marco polo
the reason why that is like that so it has no issues with the starter motor
if you mean the side that has a bit of a dish
at the end of the day this thing works and works well and it does controll the oil ..... you all ways have the same amount of oil in the sump at any one time no matter what the car is doing
accel/brake/cornering/left/ right .....the gates open and close accordingly
these are 100 times better than just wings welded on the side of the sump and holes drilled in the side
how do they controll oil speed and stop the oil rushing to the front of the engine when under heavy braking and cornering hard from left to right ?
this is a fully controlled sump that does every thing needed for track use ?
yes this sump is an over kill for just normal road use i will agree with that
the reason why it's coated just for finsih really not to gain extra money its 300 thats with or with finsh ......lol...
marco
Old Jul 23, 2008 | 09:57 PM
rsjp's Avatar
rsjp
marco
This design was taken from an Andy Rouse sump and I think he knew abit about this . Eh Marco
And there is a -8 fitting in the end which breathes upto the breather so it wouldn't create an air pocket.
Old Jul 23, 2008 | 10:01 PM
marco polo's Avatar
marco polo
exactly that !
Old Jul 24, 2008 | 04:18 AM
Garage19's Avatar
Garage19
The -8 fitting is too low. Unless you lifted the car up 4 ft when you filled it up to 45 degrees you will just end up with trapped air there.
Old Jul 25, 2008 | 07:17 PM
marco polo's Avatar
marco polo
at the end of the day ,they do exactly what they were made for
mine has -10 fitting and is not 45 degree
how can this casue an air pocket for a start most decent cossys with have a proper breathing system that breats from both sides of the block
and these have a baffle to stop oil from going up to the retern
so what sump have you got on your car ? have you got dry sump?
dry sump wins hands down , but this type of sump in next best to dry sump regaurdles what you think
marco
Old Jul 25, 2008 | 07:33 PM
Garage19's Avatar
Garage19
Marco, the breathing system has nothing to do with it.
45 deg is not the angle of the breather. It was a joke about how you would have to put the car to fill the sump up.
Look up "diving bell" on wikipedia and the principal behind the trapped air will be explained.
Old Jul 25, 2008 | 07:54 PM
marco polo's Avatar
marco polo
hi mate
to be honest if it does then i'm not too botherd , i know this sump works well regaurdless of that , all i know i have never blown an engine with this sump on ,
i have blown engines without a big wing sump of some kind
so it good enough for me
what other sump is out which is as good as this one ?
marco
Old Jul 25, 2008 | 08:13 PM
Garage19's Avatar
Garage19
I'm not saying it won't work, just that the curved up bit is pointless.
I'm sure there are other big wing and baffled sumps out there on the market that work just as well.
Old Jul 25, 2008 | 08:14 PM
marco polo's Avatar
marco polo
well get one of thoses then ...........lol....
Old Jul 25, 2008 | 08:18 PM
bbspolo's Avatar
bbspolo
garage19 sounds 2me like u should design a make a better one and sell them for less than 300 quid and u would be on 2 a winner!
Old Jul 25, 2008 | 08:22 PM
Garage19's Avatar
Garage19
What like half that price... that would be good
Old Jul 25, 2008 | 08:23 PM
marco polo's Avatar
marco polo
yep go ahead and make one
Old Jul 25, 2008 | 08:30 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Just like the plenums
Old Jul 25, 2008 | 08:35 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
marco gives you wings
Old Jul 25, 2008 | 08:38 PM
Garage19's Avatar
Garage19
