flat spot and fuel issue
Old Jul 19, 2008 | 09:54 PM
a17ddt's Avatar
a17ddt
Default flat spot and fuel issue
hi there
im new here and have just brought my first rs turbo mk 4 after owning a string of capris and sierras.
im having some trouble with the car at the mo, but not sure whats causing it.
When running low on fuel (under half tank) the engine keeps wanting to stall and cutting out when the throttle is squeezed a bit. also the fuel pump gets really loud. im sure its not the fuel pump as ive just replaced that. also, the engine seems to become very flat when you get to about 3.5k to 4k revs. regardless of how much fuel is in the car, so im not sure if these problems are related.
anyone any ideas?
thanks in advance
Dave
Old Jul 19, 2008 | 09:58 PM
Rick's Avatar
Rick
no swirl pot in the tank, and incorrect ignition timing.
Old Jul 19, 2008 | 10:07 PM
a17ddt's Avatar
a17ddt
sorry if this sounds dumb, but what would a swirl pot do?
Old Jul 20, 2008 | 02:23 PM
Rick's Avatar
Rick
it stops air getting sucked into the fuel pump, which happens when the fuel level is low. The fuel tank may be a non injection item.
Old Jul 20, 2008 | 02:32 PM
Smartdj.'s Avatar
Smartdj.
your not running way 2 much boost are you...could cause a problem...ummmm
Old Jul 20, 2008 | 03:47 PM
a17ddt's Avatar
a17ddt
no, its only running about 12psi at the moment
JK12
33
Apr 26, 2021 12:09 PM
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
hopper350
Sep 4, 2015 12:53 AM
