what boost controller????
Old Jul 19, 2008 | 04:02 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default what boost controller????
hi guys, been to alan jefferys at plymouth today, and he says that i need an electronic boost controller and basically get rid of the amal valve,so that he can set up the car properly, what do you guys have? and what do you recommended, also what price.
Old Jul 19, 2008 | 04:04 PM
foreigneRS's Avatar
foreigneRS
Testing the future
why? what are trying to achieve that an amal valve cannot?
Old Jul 19, 2008 | 04:05 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
think u'll need to give people ur spec..............it would help................as for a controller...........i use the amal valve at over 400bhp..........
Old Jul 19, 2008 | 04:08 PM
OrionRST200bhp
spec.... t34 with 63 housing, 3 bar map sensor, siemens black injectors, msd closed loop chip, stainless exhaust, and the rest K&n air filter etc...
JTECH James's Avatar
JTECH James
Passion for Fords!
he ALWAYS trys to sell you stuff you dont need.
amal valves work perfectly well
Old Jul 19, 2008 | 04:09 PM
djcossie's Avatar
djcossie
get a air injection for boost its the best
Old Jul 19, 2008 | 04:11 PM
OrionRST200bhp
i thought i'd ask on here as he reckons i need to spend £300 on a turbo smart boost controller. he did say that i needed an rs 500 cooler but i have one on order.
JTECH James
Passion for Fords!
why is it best?
when you would need live mapping to correctly run air injectors.....
amal valves are fine....its not like you need to map out surge with a t34...
Old Jul 19, 2008 | 04:14 PM
OrionRST200bhp
i had some bloke down there basically telling me to go jap as the cossie managment isnt any good compared to the japs.
Old Jul 19, 2008 | 04:16 PM
JTECH James
Passion for Fords!
full of shite, dont belive a word.
its a case of...he cant use the cossie ecus, so that makes them crap
he always trys to make me change ecus aswell, i just tell him to piss off, asif i would ever let them map my car
Old Jul 19, 2008 | 04:18 PM
djcossie's Avatar
djcossie
Default hi
Originally Posted by JTECHSAFF
why is it best?
its the best way
live mapping is the best way
and all the best things work together
Old Jul 19, 2008 | 04:19 PM
OrionRST200bhp
is there anyone else i can take my car to instead of alan jeffery around devon or cornwall without travelling all the way up to blackpool? also how much are the air injectors and are they easy to fit??
Old Jul 19, 2008 | 04:21 PM
djcossie's Avatar
djcossie
Default hi
cossie managment this the best in the right hands so that bloke is not good
so dont spend any money with him
Old Jul 19, 2008 | 04:24 PM
JTECH James
Passion for Fords!
Originally Posted by djcossie
its the best way
ii disagree.
its betrer if you need it to be mapped bleed on.....to map surge etc....
but on a t34 you could weld the wastegate shut and not have surge....
air injection also has one really bad point....
if your injector fails or gets blocked...you make all the boost your turbo can make,potentially killing your engine..
i run air injection because i need it, not because its best....
Old Jul 19, 2008 | 04:34 PM
JTECH James
Passion for Fords!
whats actually the boost problem he needs to "sort" as he says?
Old Jul 19, 2008 | 06:18 PM
I agree with Jtech, saty away from air correctors as failure melts engines, the amal valve is perfectly adequate, the std ecu is limited in boost control ,as it is on/off in action, and not load AND throttle angle determined, if you want the best setup for the road, I would get it rolling road mapped, no one including stu can control all the conditions that you can on a rolling road, ie hold rpm/power/speed function to check load sites.
By the time you add on CL, coilpack, AL, ecu,chip, mapping etc you can buy a aftermarlet ecu/loom and mapping, and have many more fucntions, even a triple map costs only £275 where I go.
Old Jul 19, 2008 | 07:29 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not true - the PWM output from the ECU is variable depending on ACT etc
Old Jul 19, 2008 | 07:33 PM
OrionRST200bhp
he reckons that the amal valve makes the boost drop off to much thats why he said get a boost controller as that wont happen. surely when i get my rs500 cooler and put that on it can be tuned to what its suppose to run, without getting air injectors and boost controllers, ive got all this stage 3 stuff on my car and he has basically got my car running less power than a stage one setup. its 250bhp............ crapppppppppppppppp is the word, thinking about it, ive been butt fooked big time.
Old Jul 19, 2008 | 07:38 PM
OrionRST200bhp
another thing he said that my car is reving 500rpm more than what my clocks are telling me, how do i sort that, or is that bulls##t aswell???
Old Jul 19, 2008 | 07:41 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It sounds like the guy doesn't know what he's doing. Amal valves do have their limitations (eg, I wouldn't want to run one at 2 bar), but they and the boost control strategy in the ecu is a 'boost controller'. The chip will be mapped for boost control I would have thought!
Speak to the calibrator (MSD), not some monkey.
Old Jul 19, 2008 | 07:49 PM
cossie daz's Avatar
cossie daz
IMO i would travel and get it tuned
Old Jul 19, 2008 | 07:53 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Heres the best thing you can do.... take it to stu at blackpool due to by the time hes fucked you about telling you this and that which is complete bullshit and a waste of money you may aswell spend that money by droping it off with stu for the day whilst you go for a nice walk down the beach with an icecream hahahaha lol SORTED.
Old Jul 19, 2008 | 07:57 PM
foreigneRS's Avatar
foreigneRS
Testing the future
he may be correct in a way - but you have the possibility of using different sized jets in the SEM valve and differently sprung actuators to control the boost how you want it without having to spend on a boost controller. although to be fair to him, a boost controller is possibly easier and gives better control in the long run.
Old Jul 19, 2008 | 08:24 PM
Jim Galbally's Avatar
Jim Galbally
ah, my mate alan. he once signed up her to try and make me sound stupid after he LOST my rather rare peice of turbotechnics equipment and didn't care
basically, whilst what youve told s not FACT, hes advising you to change the spec of your car so that HE kws what to do with it. there are many competent tuners in the UK who can deal with the standard cosse stuff just fine, so you do not NEED to change anytihng (otehr than your tuner )
Old Jul 19, 2008 | 08:26 PM
Jim Galbally
re: blackpool, i recently took a visit to MSD for a fault that 3-4 other place couldnt diagnise...
stu charged me pennies and change my SPARK PLUGS, problem solved
cost me more in fuel than the invoice.
do it once, do it right
oh, and its not just MSD, there are loads of places that know what theyre doing
Old Jul 19, 2008 | 10:08 PM
JTECH James
Passion for Fords!
i wouldnt say stay away from air injectors, they are very good, but imo on a t34 car wouldnt give much benifit...
my t34 car peaked 32psi and held 28psi, what more do you need? i could have welded the wastegate shut and not made more power ....all with a correctly jetted amal valve.....
a friend of mine took his cossie to alan jeffery, and he was unable to get the boost up over 20psi.....it came to me, and i jetted the amal, something really simple, and it made 30psi easily.........he really should know how to do this, rather than sell boost controllers you dont need....
Old Jul 19, 2008 | 10:24 PM
costina's Avatar
costina
Live long and prosper!!
Don't you just hate it when people talk bollox
Paul
Old Aug 7, 2008 | 07:32 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Hmmm, so £200 on an Apexi AVC-R could be better spent?
Old Aug 7, 2008 | 07:38 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
The man is a fucking retard.
If theres nothing else wrong, even a 5quid bleed valve would happily control the boost you have on a stg3 setup.
Old Aug 7, 2008 | 07:49 PM
jld0211's Avatar
jld0211
Default boost controller
i was told the same at totd because i peak at 18 psi but drop down to 13 he said a boost controller would hold the boost much better im running gotech from which chris todd says is poor has neone else had problems with gotech
Old Aug 7, 2008 | 07:55 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
all tuners slag off anything they dont sell or dont understand.
thats why i loath going to any tuners, they even do it with simple things like exhausts and filters to put their own brand on it, never mind more expensive stuff.
utter cunts.
and to make it worse the customers still suck em off.
and to make it even worse they go round the net and mates and shit and tell everyone else this bullshit info.
and to make it worse again they tell magazines in tuning guides and then the whole world starts hearing the same bullshit.
boils my piss.
Old Aug 7, 2008 | 07:59 PM
Gordon1's Avatar
Gordon1
utter cunts.
boils my piss.
And thats the end of that lol
Old Aug 7, 2008 | 08:03 PM
gil's Avatar
gil
i have e boost controller....fucking brilliant... i can programme diffrent boost at diffrnt rpm, means i dont have to have it at full chat all the time, helps when wet....get 6 diffrent boost settings as well......
Old Aug 7, 2008 | 08:37 PM
big_wig_074's Avatar
big_wig_074
my bleed valve is infinitely adjustable,no just 6 settings.costs next to bugger all too!fucking brilliant.
i ran a jetted amal valve at over 400bhp on my old cossie engine too.worked very well.
Old Aug 7, 2008 | 08:42 PM
gil's Avatar
gil
wansnt trying too convince you,, just give the guy an insight into mine....like he asked. happy with mine, glad your happy wiyh yours
Old Aug 7, 2008 | 10:01 PM
SS1's Avatar
SS1
HKS EVC V Boost control system on the dash. 3 levels of boost
(14/24/34), each setting fully adjustable
and get the car live mapped
http://www.motorsport-developments.co.uk/
Old Aug 8, 2008 | 02:14 PM
pete mcrash
or just buy it that way.............
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
