another s2 problem...NEWMAN CAM???
Old Jul 18, 2008 | 09:07 AM
5axo.rst's Avatar
5axo.rst
Default another s2 problem...NEWMAN CAM???
Hi all,
I've just recently had a newman cam and solid lifters, double valve springs fitted to my S2, and now everytime I start it from cold, it struggles to idle and basically runs shit
It also chucks out loads of smoke from the exhaust when revved... I had a pooper cam in it before, and never had this problem!
Once the car is warmed up, it runs fine, with no problems!
Any one had the same thing happen to them, no how to fix it???
CheeRS
Old Jul 18, 2008 | 09:11 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Did you set the lifters up correctly?
Old Jul 18, 2008 | 09:23 AM
5axo.rst's Avatar
5axo.rst
yeah, I didn't fit them but they were set up correctly! At first I had no compression in cylinder 3, but this was rectified as the lifter not being set up right! That was sorted and all seemed well.
Any ideas... Why would it be ok when warm, do you think the lifter has come loose?
Old Jul 18, 2008 | 09:46 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I reckon the lifters are set up wrong. Who did them?
Also, IMO, double springs are too harsh and not really needed with a solid-lifter cam.
Old Jul 18, 2008 | 10:14 AM
T28 RST's Avatar
T28 RST
Ok then
I didnt have double valve springs on mine
Old Jul 18, 2008 | 10:52 AM
mart rs's Avatar
mart rs
you need to modify the inlet, cold start bit, when i had my big head with solid lifters fitted they had to mod that to let more air in till it got warm.
works perfect! id give NMS a call
Old Jul 18, 2008 | 12:34 PM
5axo.rst's Avatar
5axo.rst
[quote=Christian and Beccy;3437609]I reckon the lifters are set up wrong.
Would this be the case, even though when the car is warm, it runs and comes on boost fine!
Old Jul 20, 2008 | 02:59 PM
5axo.rst's Avatar
5axo.rst
bttt
Old Aug 27, 2008 | 09:31 PM
5axo.rst's Avatar
5axo.rst
cheers for all the comments guys!
Do you think this problem could be down to the idle speed control valve?
Its running cosworth management, efi etc! Just an idea...
Old Aug 28, 2008 | 06:44 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
im running a newman cam in mine now and it's fine on the cossie management John, my car does not exhibit the same symptoms as yours.
Although it does idle a little rough until its warm, but that's because of the als mods and did this prior to the newman cam
im not running double valve spings on mine though
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
