cosworth 2wd hubs
Does anyone know the size of socket i will need to remove the big nut on the end of the shaft / hubs , i measured it to 41 mm but want to check before i order one .
Thanks Travis .
Thanks Travis .
From memory 41mm sounds about right from when i had to get one, as long as you have measured from flat face to oppisite flat face it will be right and get impact obviously
FlashRS
13
Aug 31, 2015 06:02 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 14, 2015 07:29 AM
