help needed pls
Old Jul 10, 2008 | 09:48 PM
rsdara's Avatar
rsdara
Default help needed pls
hello all just brought my self a s2 rs and when i brought it it was not running to well it seems to be really flat and when the boost comes in it starts to pop and fart
it has had changed
plugs
leads
dizzy
coil
fuel filter
but still the same can anyone help me as it is really bugging me
Old Jul 11, 2008 | 06:48 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
timing belt may have slipped.
was it running ok before you changed these parts or did you change these parts in an attempt to cure the problem ?
Old Jul 11, 2008 | 07:32 AM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
check the position of the dizzy with the head, try rotating it to retard/advance bout a mm at a time, but dont go thrashing it, you will know if it makes a difference from driving safely
Old Jul 11, 2008 | 04:51 PM
rsdara's Avatar
rsdara
tried to adjust the dizzy made no difference it only does it when it is warm i have found today i ran it when it was cold and it was fine but as soon as it is warm it plays up
Old Jul 11, 2008 | 08:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
overboosting, lack of fuel...more fuel when its cold from cold start valve so runs 'better'
get it set up by a pro !!!!
Old Jul 11, 2008 | 10:54 PM
MartinRS's Avatar
MartinRS
can the fuel pressure be adjusted on these?
Old Jul 12, 2008 | 04:15 PM
vroooom ptssssh
It Wasnt Me!
Yes, but I wouldnt personally adjust it unless I knew what I was doing at the risk of my engine
Old Jul 12, 2008 | 05:04 PM
rsdara's Avatar
rsdara
how do you adjust the fuel pressure ?
also unplugged what i think is the boost temp sensor on the metal pipe that runs over the rocker cover and it only did it slightly and thn was fine
Old Jul 12, 2008 | 07:01 PM
Rick's Avatar
Rick
it is popping because it is running very lean. Probably too much boost for the fuel pressure - it needs looking at by a pro.
Old Jul 12, 2008 | 07:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
yeah turn the boost down and see how she runs, or like everyone else says get it on the RR and setup properly!
Old Jul 12, 2008 | 07:47 PM
bezo's Avatar
bezo
powered by K26
what boost are you running out of interest?
Old Jul 13, 2008 | 10:57 AM
rsdara's Avatar
rsdara
its only running at 4 psi
Old Jul 13, 2008 | 11:56 AM
Karlos G's Avatar
Karlos G
Balls Deep!
4psi??? Sounds like the Amal valve is dead, that will cut your boost right down to about 4psi i believe.
Old Jul 13, 2008 | 12:00 PM
TommysKeeper's Avatar
TommysKeeper
I had this years ago on my S1 when the Ford dealer overfilled with oil - Fine when cold but sick when warmed. Took another branch of dealership about a week to clean out and replace parts to remove excesses. It's OK though they are no longer a Ford dealer!
Old Jul 13, 2008 | 08:39 PM
rsdara's Avatar
rsdara
sayin that the oil is over the mark by a bit also the amal valve has been taken out
Old Jul 15, 2008 | 07:49 PM
rsdara's Avatar
rsdara
tried changing the fuel metreing unit and still the same
Old Jul 15, 2008 | 08:45 PM
mart rs's Avatar
mart rs
take it for a set up dude! will prob be cheaper by the time you have done buying parts that are not needed!
it will run great an go well
Old Jul 15, 2008 | 09:19 PM
rsdara's Avatar
rsdara
i no people keep sayin take it for a set up but what else could they do that i havent
Old Jul 15, 2008 | 11:18 PM
MartinRS's Avatar
MartinRS
needs to fix the problem really before it can be set up as cars not really drivable, as soon as you put the engine under load(as in pulling off slowly) it starts to miss and sounds like antilag poping and banging!
JoeyBoyden
Jan 4, 2024 02:36 PM
martinmilne
Oct 18, 2019 02:18 AM
borboyous
Aug 22, 2015 11:17 AM
cozzy jeff
Aug 14, 2015 05:46 PM
col93saphcos
Aug 7, 2015 03:21 PM
