Problem with RST
Old Jul 10, 2008 | 07:24 PM
Pat's Avatar
Pat
Default Problem with RST
I`m in need of some advise.. I have a 2.1zvh ERST EFI..
Took it out sat night all was good... stopped at garage and put full tank of fuel in.. Set off and 5 mins later after coming off a roundabout it started playing up, wont boost and starts jerking, really had to tickle throttle to get it home.. Car ticks over fine and revs fine, doesnt overheat, no smoke or anything usual.. Only think i found was exhaust manifold is blowing heavily.. But soon as you go to drive it it wont play ball
Amy ideas?
Only thing that comes to mind it that when i filled it up it has sucked something down fuel pipe and blocking fuel
Old Jul 10, 2008 | 07:35 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default manifold
mate do you think you should fix the manifold first just to be on the safe side??definatly the right fuel?
Old Jul 10, 2008 | 09:18 PM
Pat's Avatar
Pat
Manifold is been done first... but i really dont think its that.. and yes a full tank of optimax went in..
Old Jul 11, 2008 | 06:36 PM
Smartdj.'s Avatar
Smartdj.
yer deffo fix the manifold first and that will probaly cure the problem....they dont like air leaks remember..good luck
A.t.p
Oct 23, 2015 07:54 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
