Help needed! Non starting Saff - strange one.
Old Jul 8, 2008 | 07:06 PM
XRT_si's Avatar
XRT_si
Default Help needed! Non starting Saff - strange one.
A mate has a totally standard 2WD Saff. Hasn't had it long, but it started missing in higher revs. So he parked it up, a week later and car doesnt want to start.
It turns over, gets fuel, just no spark.
So far swapped:
-Rotor Arm
-Dizzy
-Coil
-CPS sensor
-Phase sensor
-Plugs
-Leads
-ECU
And still no spark. Tried bridging the wiring for the coil to give it direct feed from battery and still no luck.
Any one got ANY suggestions, he's getting REALLY pissed off now understandably. Or is there anything we may have missed to try and test?
Had a few mates who have a good idea about Cossies have a look at it an no luck.
Only thing left to try is removing the alarm has its been suggested the immobiliser is kicking in, but when it actually activated the car doesnt even turn over?
Anything else?
Old Jul 8, 2008 | 07:14 PM
big_wig_074's Avatar
big_wig_074
earth lead?
Old Jul 8, 2008 | 07:24 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the std ford alarm cuts spark only....
i bet its still in place...
have you tried locking\unlocking with key?
Dan16v's Avatar
Dan16v
crank sensor?
Old Jul 8, 2008 | 07:27 PM
Sticky.'s Avatar
Sticky.
Check the crank pulley.
Old Jul 8, 2008 | 07:47 PM
XRT_si's Avatar
XRT_si
Check it for being bent/loose/borken I assume?
Cheers for the suggestions fellas
Old Jul 8, 2008 | 07:48 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
I knew someone who had this problem and parked the car up for 10 years because of it. Turned out after doing all the usual chacks etc., the yellow relay under the dash was fooked. He had already changed it for a spare, but that was fooked too. It was a 4x4 though so dont know if its the same setup on 2wd. HTH.
mk22door
49
Mar 26, 2022 07:15 AM
Ben26
Aug 11, 2015 04:19 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
col93saphcos
Aug 7, 2015 03:21 PM
Sjieter
Aug 5, 2015 09:47 PM
