fuel pressure gauges.
Old Jul 7, 2008 | 10:56 AM
R5FORD's Avatar
R5FORD
Default fuel pressure gauges.
whats the best aguges to go for? one under the bonnet or in car?
Old Jul 7, 2008 | 10:59 AM
R5FORD's Avatar
R5FORD
defi one looks good
Old Jul 7, 2008 | 11:01 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
WTF use is one under the bonnet ?
Old Jul 7, 2008 | 11:12 AM
xr4x4rs's Avatar
xr4x4rs
i use an autometer one
Old Jul 7, 2008 | 11:13 AM
R5FORD's Avatar
R5FORD
yh i know.. i just thought after i posted this
Old Jul 7, 2008 | 11:17 AM
Rolls's Avatar
Rolls
I've got a defi in mine - very handy bits of kit!
Old Jul 7, 2008 | 11:21 AM
R5FORD's Avatar
R5FORD
yh im going to order a 60mm defi Bf one.. just thinking what other gauge i will need aswell. Mike any other vital gauges i need? i got voltage, oil pressure,boost.
I would have gone for a stack AFR gauge ut they dont make them 60mm.
Old Jul 7, 2008 | 11:22 AM
Kelv's Avatar
Kelv
Almost there!
Stack for me
Old Jul 7, 2008 | 11:25 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i've often seen those small ones in the fuel line and wondered what the point is. they will tell you the fuel pressure at idle, but won't tell you if it's being raised on boost when it's most critical and when your fuel pump may not have enough capacity
Old Jul 7, 2008 | 11:27 AM
rsnissan's Avatar
rsnissan
I have an SPA one seems to do the job and dont look too flash for the old interior. has peak value and can run a trigger if its too low or too high.
Old Jul 7, 2008 | 11:30 AM
Mike Rainbird
Caraholic
The good thing about the Defi gauges is that if you buy the Defi boost gauge as well, you can use the fuel pressure differential function. What this does is warn you if the fuel pressure doesn't rise at the same rate as the boost like it should do .
Ginge !'s Avatar
Ginge !
just finding my feet
but they look like a race car when you lift the bonnet pmsl
ive often wondered the point of oil presure gauges,,,,, as when its dropped the engines alread fucked aint it ?
oil temp is good,,, voltage,,,, erm not sure on that tbh cause that tells the battery not the power to the pump/ecu which would be more important im sure
boost is good though as it moves and AFR ( one that works ) is also good
Old Jul 7, 2008 | 11:32 AM
R5FORD's Avatar
R5FORD
mike dont tempt me to buy a boost gauge aswell
Old Jul 7, 2008 | 12:00 PM
Nash's Avatar
Nash
Cake lover!
Its a very good gauge Ginge, You can see if the oil pressure is to low or not rising with the revs. Imagine if you didnt have the Gauge? you wouldnt know the pressure was low untill it was to late.
My gauge saved my engine atleast once as i noticed the pressure dropping. Turned out the oil return from the turbo was split.
Old Jul 7, 2008 | 12:30 PM
Franco's Avatar
Franco
Learn something new everyday!
Old Jul 7, 2008 | 12:39 PM
Mike Rainbird
Caraholic
On the Defi's you can set the alarm warning function as high as you want. You are confusing the standard oil light with a proper gauge, as by the time this comes on, your engine is most likely fucked. However, I have my warning set at 2 bar, so this should give me plenty of warning if it goes below this in normal driving. Obviously it is on at idle, but I know that isn't a problem.
Old Jul 7, 2008 | 12:40 PM
Kelv's Avatar
Kelv
Almost there!
that not hard tho is it Jase
Old Jul 7, 2008 | 12:55 PM
Franco's Avatar
Franco
Anyone wanna swap a black Defi 60mm fuel pressure gauge brand new, for a white one!
Old Jul 8, 2008 | 12:10 AM
Red16's Avatar
Red16
how cool is that
Old Jul 8, 2008 | 07:48 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Not into these bid defi gauges. Much prefer the normal size ones. Any recommnedations for them?
Old Jul 8, 2008 | 08:08 AM
Ginge !'s Avatar
Ginge !
mike im not, just stating that most times the presure has dropped in a engine means the engines fucked,,,,,,, ok you find the problem but theres a good chance its too late
ok a few reasons it may help.... but most times its just gonna get you paranoid
ps: yes i have a oil presure gauge in my car anyway
a alarm is a great idea,,,,, but whats the most comon reason for the oil presure to be low ?
Old Jul 8, 2008 | 08:40 AM
Mike Rainbird
Caraholic
Ginge,
I'm not saying it will save you engine in every scenario, because if it is fucked, it is fucked, you just know about it sooner to perhaps save a catastrphic failure (rod through side of block etc), but certainly in Nash's example, it saved his engine.
Old Jul 8, 2008 | 08:48 AM
Ginge !'s Avatar
Ginge !
Ginge,
you know what im getting at though, im not arguing,,,, just commenting about the general irony of the oil presure gauge as most times it just tells you bad news
Old Jul 8, 2008 | 09:20 AM
Mike Rainbird
Caraholic
There is no good or bad news, just news .
Old Jul 8, 2008 | 09:24 AM
Ginge !'s Avatar
Ginge !
mike when my gauge drops below 2 bar when driving,,,, well its FAR from just news. im gonna cry like a bitch !!!!
Old Jul 8, 2008 | 09:28 AM
Franco's Avatar
Franco
You found me a white 60mm fuel pressure gauge yet Mike?
Come on, chop chop!
Old Jul 8, 2008 | 09:31 AM
Mike Rainbird
Caraholic
I think Neil A has one in his car that he is thinking of breaking .
Old Jul 8, 2008 | 09:45 AM
Franco's Avatar
Franco
Old Jul 8, 2008 | 09:46 AM
foreigneRS's Avatar
foreigneRS
Testing the future
what use is a broken gauge?
Old Jul 8, 2008 | 09:51 AM
KSA-Cossie's Avatar
KSA-Cossie
Who's been to see kung foo panda then ??
Old Jul 8, 2008 | 09:58 AM
Mike Rainbird
Caraholic
Two of us .
Old Jul 8, 2008 | 09:59 AM
Ginge !'s Avatar
Ginge !
Two of us .
and me but i fell asleep near the end
that candle blowing out bit with the turtle at the start was fucking hillarious
KSA-Cossie's Avatar
KSA-Cossie
Two of us .
Busted .
Old Jul 8, 2008 | 10:35 AM
Mike Rainbird
Caraholic
At least I have an excuse - I took my five year old daughter - and yours is?
Old Jul 8, 2008 | 10:36 AM
Ginge !'s Avatar
Ginge !
hey mike i ALSO took my FOUR year old daughter,,,, she loved it too might i add
Old Jul 8, 2008 | 10:53 AM
KSA-Cossie's Avatar
KSA-Cossie
I took my 10 yr old son to it,and fell asleep missing the ending.
Old Jul 8, 2008 | 02:01 PM
Mike Rainbird
Caraholic
It was the best ever ending of all the films you have seen .
Old Jul 8, 2008 | 02:08 PM
Franco's Avatar
Franco
You thought wrong Mike, get searching!
Old Jul 8, 2008 | 02:39 PM
Mike1's Avatar
Mike1
What's your oil pressure at idle when your oil temp is 108 deg C Mike? ( I figured if anyone knew or kept records it would be you )
rapidcossie's Avatar
rapidcossie
would imagine it must be very low at 108 deg!
