cam pulley question
Old Jun 30, 2008 | 03:54 PM
garrett-killer's Avatar
garrett-killer
Default cam pulley question
hi!
are inlet,outlet and dissi pulley´s the same?
could i use a dissi pulley instead of a cam?
best regards chris
Old Jun 30, 2008 | 04:17 PM
MONSTER's Avatar
MONSTER
No the dizzy pulley is slightly different in depth, it'll sit either too far in or not far enough I can't remember which.
Old Jun 30, 2008 | 04:36 PM
garrett-killer
thank you,but the timing would be the same?
Old Jun 30, 2008 | 06:30 PM
MONSTER's Avatar
MONSTER
can't see why not, as long as the marks are in the same position & its got the same number of teeth
Old Jun 30, 2008 | 10:41 PM
Kelv's Avatar
Kelv
Almost there!
why would you want to use a dizzy pulley instead of a cam pulley tho?
Old Jul 1, 2008 | 05:10 AM
garrett-killer
no,i dont want it,but the previous owner made full sh*** on my car,
and i dont know why it is to rich on boost and made no good power.
could wrong cam timing made it to rich/inefficient ?
the car runs fine with a msd chip on greys,but once it made boost it goes rich.
the more boost i drive,the richer it gets.
( afr 11,5 on 1bar boost and 10,0 on 1,7bar)
and it made no more power on higher boost.
perhaps someone could help me,i tried really everything !!
best regards chris
Old Jul 5, 2008 | 06:14 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
it will deffo not fit as the offset and diameter on the axel is not the same.
To me it sounds like the fuel-pressur regulator is wrong or the map is totally off, have seen some maps are made for greens but people put grey or light blue in to get it more rich without changing the fuel map
Old Jul 6, 2008 | 04:02 PM
legend289's Avatar
legend289
They do vary on diameter, we looked at using cam wheels on the dizzy shaft for reasons i won`t go into here, but it would be possible to make something work if necessary. It should be obvious if they did though, the modification should be pretty obvious.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
