General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
B, me and the old man are both running roughly the same spec as you and we use either felpro or cometic, there are cheaper ones but it aint really an area to skimp on!!
hi there mate
A. im always up quite early
B. cheers for reply,i was going to go for WRC gasket but not sure if over kill and quite pricey at roughly £350!!
YB0611 and wire wrung block, bit old fashioned, but still works very well, plus if the worst does happen and you blow the gasket its only another 55 quid.
ive had 3 cossies on group a and 2 of the have had pressure and overheating issues and 2 cossies on wrc and never a problem with either.
i just rebuilt mine with a group a i think its 3 layers metal i also got a wire ringed block but advised not to putthe wire in should i exspect problems not even run in it done 280 miles
