torque settings??
Old Jun 27, 2008 | 02:20 PM
SWIFTY's Avatar
SWIFTY
Question torque settings??
can anyone tell me the settings or where i can get them from for the cam caps and arp stud an nut kit for a 2wd thanks
spelling is not my strong point
Old Jun 27, 2008 | 04:14 PM
LHD220Turbo's Avatar
LHD220Turbo
cam caps are 16nm from memory but i'm not 100% on that, i'm sure someone else will confirm
The ARP's are 81ft lbs for ARP moly assembly Lube
( or thread sealer) or torque to 105 ft lbs with 30 wt motor oil.
Old Jun 27, 2008 | 06:07 PM
I always do my ARP stud/nuts to 130lbft, wait a minimum of two hours and retorque.
I lightly apply oil to the threads with my fingers, engine oil.
Old Jun 27, 2008 | 08:17 PM
SWIFTY's Avatar
SWIFTY
Is That For Both The Stud And Nuts???
Old Jun 27, 2008 | 08:26 PM
LHD220Turbo
just the nuts
Old Jun 27, 2008 | 08:28 PM
SWIFTY's Avatar
SWIFTY
Ok Mate What Do You Do The Studs Up To????
Old Jun 27, 2008 | 08:32 PM
LHD220Turbo
how are you going to torque the studs? you can't! they are round
Old Jun 27, 2008 | 08:43 PM
SWIFTY's Avatar
SWIFTY
DONT UNDERSTAND WHAT YOU MEAN??
ON MINE THERE IS A HOLE IN THE TOP FOR AN ALLEN KEY.
Old Jun 27, 2008 | 08:46 PM
LHD220Turbo
not sure then mate
Old Jun 27, 2008 | 09:15 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
studs finger tight, then back them off 1/4 turn, dont do them up,
this is how they have probs breaking blocks imo
Old Jun 28, 2008 | 05:51 AM
Block cracking is caused by people not cleaning out the holes that the studs go into, they contain old congealed oil, always clean these out and run a tap down them.
When I did mine I measured the depth of the holes, which were at least 4mm longer than the studs themselves, I just screw in finger tight, then a tweak with a grip on the stem of the stud, they have a shoulder at the bottom anyway to prevent them from going too far in, personally I don't beleive any block is cracked by the application of studs, more likely head trying to lift from too much pressure.
steve.rst
Mar 15, 2016 08:01 AM
lime
Sep 25, 2015 06:56 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
