Nitrous questions
Old Jun 27, 2008 | 10:45 AM
Rippers's Avatar
Rippers
Monte Geek
Default Nitrous questions
Sorry if these are silly questions but how does nitrous effect the con rods of the engine ie people say if you want nitrous you need to uprate the rods, is this purely because of the extra strain the burst of power causes or is it for another reason.
At what levels of power and amounts of nos do these become problems.. example engine Focus RS at about 270bhp??
Thanks Paul
Old Jun 27, 2008 | 10:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Most conrods fail on the start of the exhaust stroke as they stretch, so its revs that kill them not torque generally.
BUT if you have a weak rod that cant handle torque then it will fail with nitrous torque just the same as it would from any other type of torque, ie more boost or other VE improvements.
Old Jun 27, 2008 | 10:49 AM
sbd16v's Avatar
sbd16v
its because of the ablility to run a very large amount more power lower in the rev range and that means alot more Tq generated
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Thanks Paul
You're not worried about the Ka are you
Old Jun 27, 2008 | 10:51 AM
Rippers's Avatar
Rippers
Monte Geek
Ok, so basically it all depends on the power/torque level.
How effective would say a 25/50 shot of nos be on a 270 FRS engine? (roughly)
Old Jun 27, 2008 | 10:53 AM
Rippers's Avatar
Rippers
Monte Geek
It would be for a FWD quatermile time so would want to use the nos in end of third gear all of fouth gear??
Old Jun 27, 2008 | 10:54 AM
Rippers's Avatar
Rippers
Monte Geek
maybe
pani_k's Avatar
pani_k
PassionFORD Member
Nitrous needn't be a huge burst like an on/off switch though. You can graduate it in using electronic control.
Old Jun 27, 2008 | 10:55 AM
Benni's Avatar
Benni
Ban[B][/B]ned
Progressive?
Benni.
Old Jun 27, 2008 | 10:57 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
maybe
Grudge match
It'll be fair, two completely different cars
Ones a fast little red car, the others your Fiesta
Chip's Avatar
Chip
25 bhp you will bearly notice, 50bhp will make a nice difference, id be using it progressively right off the line though to allow you to hook up at lower rpm
Old Jun 27, 2008 | 10:58 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Uprated conrods for nitrous is usually reccomended by the same folk who reccomend an uprated head gasket for more boost.
Ie the people whos cars are detting like fuck, blowing head gaskets and bending rods.
Old Jun 27, 2008 | 10:59 AM
Benni's Avatar
Benni
Ban[B][/B]ned
In something like a Ford Focus 100bhp you would notice it though, wouldn't you?
Benni.
Chip's Avatar
Chip
Agreed!
Old Jun 27, 2008 | 11:04 AM
Chip's Avatar
Chip
Benni.
Yes definately, but its an expensive way to still be in a slow 125bhp car!
Old Jun 27, 2008 | 11:06 AM
Benni's Avatar
Benni
Ban[B][/B]ned
I would never consider it, I was just curious.
Benni.
Old Jun 27, 2008 | 11:36 AM
Rippers's Avatar
Rippers
Monte Geek
Are these a stand alone set up ie would the car have to me mapped around the nos?
Old Jun 27, 2008 | 11:42 AM
DangerousBryan's Avatar
DangerousBryan
stand alone so no need to touch the cars map at all.
have a look here
http://www.noswizard.com/index.php?c...660d8519f80147
bryan
sbd16v's Avatar
sbd16v
no using a wet system so the fuel and nitrous is supplied by the kit
Old Jun 27, 2008 | 12:12 PM
Chip's Avatar
Chip
It depends on the power level you are adding.
On my YB I have to take a little timing out when on the gas, but I do that via the octane wires so the map hasnt been touched, not sure what the options are in that respect on the focus lump though.
Just a case of det checking and seeing, on SBD16V's motor we were running 125bhp of nitrous with no timing taken out at all, and it didnt have any issues, but its not always the case.
Old Jun 27, 2008 | 12:15 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
To be honest, I don't really see the point in Nitrous until you are at the engines realistic tuning limit for sensible outlay, with the FRS you would be better off just going up to the next stage of tune IMHO....
N/a is a different matter as power is so expensive per BHP then it makes sense.
Old Jun 27, 2008 | 12:23 PM
Rippers's Avatar
Rippers
Monte Geek
I think its trying to get a level of power to grip ratio right on the FWD. I have no idea why my old Fiesta used to perform so well @ 270bhp when all my competitors with similar set ups but much more power where doing much higher terminals but poorer times. Maybe my power range was better then the bigger turbo'd cars, my Fiesta certianly had no lag issues.
So if I got the next power stage it would be a T34 which may shift the power range up too high. Where as the nos would just be extra power on top of what I have. I always felt that the 1st 2nd and 3rd where ok on the quarter but 4th gear could have done with a bit more to pull across the terminal a bit faster.
It all down to experimenting at the end of the day
Old Jun 27, 2008 | 12:25 PM
sbd16v's Avatar
sbd16v
drivability
Old Jun 27, 2008 | 12:32 PM
Chip's Avatar
Chip
That depends, I bet you would change your mind if you drove my YB with a T34 and 125bhp jets in it.
SO much better to drive than a T4 one, its not even comparable!
(much more expensive if you use it a lot on the gas though!)
Old Jun 27, 2008 | 12:35 PM
RWD_cossie_wil
Thats my problem with it really , i'm sure it fantastic fun, but whats a 22lbs refill, about Ł50?. IMHO it's GT30 time for that sort of dosh. Can you not steal it from a hospital?
Old Jun 27, 2008 | 12:36 PM
Rippers's Avatar
Rippers
Monte Geek
For the quarter mile its not over expensive
Old Jun 27, 2008 | 12:37 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I think you'd need progressive control for any reasonable amount of nitrous on fwd though.. Having a 200+ ft-lb torque spike at 2000rpm ain't gonna do you much good for traction.
Old Jun 27, 2008 | 12:39 PM
Chip's Avatar
Chip
Standard price is 6 quid a lb, and 11lb bottle lasts about two minutes of full throttle on my car.
Thats 50p a second
SO much better than any GT30 is though to actually drive!
Nova is having GT35R + nitrous, so best of both worlds.
Old Jun 27, 2008 | 12:43 PM
RWD_cossie_wil
Ł6 a Lb
Old Jun 27, 2008 | 12:46 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You can get it for half that chip if you buy a big bottle
Old Jun 27, 2008 | 12:48 PM
Chip's Avatar
Chip
Indeed, I do exactly that mate.
I was just saying thats the normal retial price.
Bottle is dear if you dont use a lot though, cause of delivery cost and rental etc, so still expensive.
Old Jun 27, 2008 | 01:07 PM
percybigun's Avatar
percybigun
Twistin me melon man
surely for the cost of a NOS kit on a focus RS, you could buy engine mods that would give you a permanent 25-50bhp power hike?
and remember NOS is useless when the bottle is cold (i.e. most of the year round) and even with bottle heaters it takes quite a while to warm them up. and i cant be arsed lugging the bottle in and out of the car to keep it warm in the house etc. so it tends to never hardly get used.
Old Jun 27, 2008 | 01:08 PM
Chip's Avatar
Chip
Utter nonsense, it works fine cold, just needs jetting accordingly.
SO much bullshit out there about nitrous!
Old Jun 27, 2008 | 01:09 PM
percybigun's Avatar
percybigun
not on mine it doesnt, jet size and AFR was checked on a rolling road while the bottle was warm.
say what you want chip, when mine is cold hardly anything happens. proof is in the pudding
Old Jun 27, 2008 | 01:10 PM
Chip's Avatar
Chip
You fucking retard
can you not see the problem with what you just said?
Old Jun 27, 2008 | 01:11 PM
percybigun's Avatar
percybigun
whats the point of having to get it check on a rolling road every time the weather temp changes?
why the hostility and cuntish posts?
Old Jun 27, 2008 | 01:12 PM
Chip's Avatar
Chip
I wasnt hostile, was just laughing at you not being agrressive.
Did you map your car at 20psi and then copy the values to the cells for 10psi?
If not why not?
Jim Galbally's Avatar
Jim Galbally
if youre interested in short bursts of speed (ie 1/4m) then nitrous is the most cost effective and sensible tuning option i can think of!
want a fast road car or track car tho and it makes less sense.
how many other modifications can you bolt on in an hour, cost 500quid and give you a 50-100% power increase on pretty much any car out there?
Old Jun 27, 2008 | 01:13 PM
Jim Galbally
what do you mean youre checking the AFR ona roalling road?
that's the Air/Fuel ratio, right?
the air isn't made up of 50+% nitrous oxide
Old Jun 27, 2008 | 01:14 PM
percybigun's Avatar
percybigun
i meant checked it wasnt over/under fuelling when nitrous is in use?
i.e. isnt that what your supposed to get checked
