Nitrous questions
#41
if youre interested in short bursts of speed (ie 1/4m) then nitrous is the most cost effective and sensible tuning option i can think of!
want a fast road car or track car tho and it makes less sense.
how many other modifications can you bolt on in an hour, cost 500quid and give you a 50-100% power increase on pretty much any car out there?
#42
*** Sierra RS Custard ***
Yes, but you checked it wasnt over fuelling at 900psi of nitrous pressure
then used the same ratio jets at 500psi, and complained it wasnt as powerful, I wonder why
Nitrous instalation advice from a decent company like WoN tries to be idiot proof, but come on mate, there is only a finite amount of idiocy they can take into account, they cant help it if somone invents a bigger idiot than they allowed for
#43
Twistin me melon man
nah its all about this ego thing of trying to look big and hard, rewording things to make others look thick, swearing/flaming at others on here unprovoked, trying to get a reaction when all your really doing is make yourself look like a keyboard warrior busting for a fight who needs anger management
#44
overfueling for what to, the AFR for atmospheric air is different to that of nictours oxide. thats why people jet them based on static tests etc. rather than hook up AFR gauges. as if you set it to 13:1 it'd probably fucking explode
where's you take the car to get this work done by the way?
#45
Ok, never really having been involved with nitrous, obviously the pressure drops as the bottle runs lower, how do you get round this? I assume bottle heaters are there to try and keep the pressure constant?
#54
Jetting your nitrous setup on a cold bottle is risky business IMO unless you jet it very rich that is which tbh is fooking pointless.
Air temps change WAY to much and the sensible way to do it is with a bottle heater with a pressure controlled shut off.
I've always used my bottles at around 900-1000psi, before I used a heater I used nitrogen.
#55
Colossal Pervert
Do ambient temperatures really have that much of an effect on a nitrous bottles pressure though when in-use? I would have thought the consumption of the gas would provide 99% of the temperature (and thus pressure) change.
#56
I've known a fair few nitrous bottles to bleed off in cars when sitting up the pod in the summer.
On a coldish day I would be lucky to see 600psi from my bottle if it wasn't full, on a hot day I've seen it creep past 1000psi and I've had to adjust the BOV to stop it emptying itself in my car.
#58
Happily retired
#60
Providing you have a pressure gauge its not an issue at all, you just swap the nitrous jet (leaving the fuel one alone) to match the pressure you have, I do it all the time, cold nitrous actually suffers marginally less phase change as well, so in that respect is better!
#61
I'd rather not have to fuck about with it tbh, I prefer to be able to switch it on and use it without having to dick around swapping jets or resetting the pozy maximiser
I'm not saying I haven't jetted it on a cold bottle before but the results are far better on a 950psi jetted system.
#62
escort mk4 cossy 4x4
i run 550 bhp with a 40 shot of nos as a anti-lag,and it works really well. breaks the rear diff every time.
#63
Glad someone agrees lloyd
We've done LOADS of testing on my mates Corvette and we know what works and what doesn't and 8/10 what were told to do doesn't work, its been a hell of a journey for my mate but his car has finally shown its true potential.
#64
I like to aim for 950psi as well, but you certainly CAN get good results on less if its well managed.
