my car still wont spark
Old Jun 22, 2008 | 12:58 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
Default my car still wont spark
i was wondering is there anybody in durham or sunderland with an rs turbo s2 who knows alot about these and the problums they have. iv bought a whole new ignition system except the ht leads and still no spark anybody got any ideas.im realy coming close to breaking the car any realy dont want to but its totally doing my head in HELP!
Old Jun 22, 2008 | 01:00 PM
orionmojo's Avatar
orionmojo
one of my mates' ones had a melted black wire from the ECU, under the fusebox ad into the car behind te dash, he replaced most of the ignition system too, and then borrowed my ecu. this is when we noticed!
Old Jun 22, 2008 | 01:08 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
yeah iv been messing round with th same wire gos right up into the ignition never noticed if it was melted though iv also put a new ecu onit new dizzy (Ł150 wot a rip) new plugs new coil new new dizzy cap and arm i will check that wire again cheers i no its gunna be something real simple but its had me baffled for 6 months nearly
Old Jun 22, 2008 | 01:13 PM
vinnyvangough's Avatar
vinnyvangough
I aint got a clue but i'm sure someone was telling me a while ago they had a relay gone. not sure if there is one???
Old Jun 22, 2008 | 01:15 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
yeah this is also sumit ive been lookin into but it al seems to be fine if any1 has a pic ov there fusebox and relays it would be a big help! cheers
Old Jun 22, 2008 | 01:17 PM
mechanic28's Avatar
mechanic28
how did u check the relay
Old Jun 22, 2008 | 01:20 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
i basicly just checked to make sure they r in the right place and then checked they wernt burnt on the prongs and i have more then one of most relays so i swaped them about i still nothing i havent got a clue how to check them properley is there a right way?
Old Jun 22, 2008 | 01:24 PM
Dan16v's Avatar
Dan16v
have u tried the crank sensor?
Old Jun 22, 2008 | 01:26 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
hello m8 it dnt have one the frst has them but not the erst
mechanic28's Avatar
mechanic28
u need a 9 volt battery (the square looking ones)and a voltmeter,but the volt meter to check continuaty (sp)then but the battery across terminals 85 and 86 relay will click then get someone to put the voltmeter across terms 30 and 87 if all is good u should get continuaty!
Old Jun 22, 2008 | 01:29 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
that sounds complicated but ill give it a shot i think its more likely that its a relay in the fuse box in the wrong place but i realy dont no . does anyone know if these have ignition relays or is it all done in the ecu?
R5FORD's Avatar
R5FORD
seeing if the realays are in the right place isnt going to tell you if they work..you need to do as above.. ahve you checked that the spare relays your using are not faulty?
Old Jun 22, 2008 | 01:34 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
no but if there not in the right place then theyl never work but i didnt know how to check them before but do now
Old Jun 22, 2008 | 01:37 PM
mechanic28's Avatar
mechanic28
its easy fella to check them,that is if u have a voltmeter
Old Jun 22, 2008 | 01:40 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
yeah i bought one a few weeks ago to check the coil has power which it doesnt but yeah i have one. the shit thing about this is that it did start first time everytime since i put the engine in then i pop a driveshaft and fook all is there when its time to start again
Old Jun 22, 2008 | 01:42 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
had this on my rst, took days to find it, everything tied up. even the break out box readings.
fault was a short circuit from the coil to the ecu on the spark recgonition sensor wire.
there should be a small green wire coming from the coil, runs round the front past the lights, rad and back up to the fuse box.
if u can check this wire is not broken/shorting. it could be ur problem
Old Jun 22, 2008 | 01:43 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
make sure the loom acorss the front of the car hasnt been cut,the coil wires are pretty exposed,also has it got a immobilizer??
Old Jun 22, 2008 | 01:46 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
i.e. the little green wire
Old Jun 22, 2008 | 01:47 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
Originally Posted by Lee Ivatt
had this on mine, took days to find it, everything tied up. even the break out box readings.
this might sound stupid but this wire it cut chopped in everyway possible but its all solderd and taped i had to cut it for some reason when i put the loom in the wires werent long enough so they now go along the back ov the engine bay past the battery my car i a total bodge when i come to think about it haha. does anyone know where the other green wire gos as i know one gos to the ecu
Old Jun 22, 2008 | 01:48 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
no it aint got an imobolizer
Old Jun 22, 2008 | 01:51 PM
orion_crazy_carl
orion=mini saff
sounds like u should just replace the loom,it aint hard and pretty cheap to do!cut ya losses
Old Jun 22, 2008 | 01:54 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
lol this is the second one but u may be right! but it acnt be much wrong when everything else is working on the car thats why im tryin to get this one workin and it a lot ov cutting and soldering when its in a cabby
Old Jun 22, 2008 | 01:56 PM
mechanic28's Avatar
mechanic28
sounds like u might have found it!check the resistance of this wire!bet it is sky high!specially if u got lots of joints in her!
Old Jun 22, 2008 | 02:01 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
do ya think so i hope! wot ya think do cut it and put one long piece of wire in ? ill hold my hands up if thats wot its been wots happens if its got lots ov joins ? just thinkin tho m8 the black ones the power and the coil had no output will the fuked wire make it resist
Old Jun 22, 2008 | 02:03 PM
xr4x4rs's Avatar
xr4x4rs
check the wiring from the dizzy plug, just disconnect everything and un tape all the dizzy wiring to make sure there isnt a broken wire, you have to go through alot fo the loom and keep doing continuity tests to make sure
thats the only thing i can think is its going to be a broken wire somewhere wither dizzy side or coil side
Old Jun 22, 2008 | 02:11 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
yeah i hope so m8 ive had the engine out last weekend and the interior out this weekend i just hope its something easy to get to cheers
Old Jun 22, 2008 | 03:05 PM
xr4x4rs's Avatar
xr4x4rs
the coil wires run from the fuse back to the front cross member in front of the rad, so you may have to take the bumper, rad and intercooler off to get to the wiring to check it properly aswell
Old Jun 22, 2008 | 03:22 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
na mine dnt thats why theres possibley a problum mine now run along the back ov the engine bay im goin out 2 give it a go now cheers for all ya help lads thnks
Old Jun 22, 2008 | 05:10 PM
xr4x4rs's Avatar
xr4x4rs
it carnt do, all mk4 escorts run the same way as there tied into the main loom
Old Jun 28, 2008 | 09:18 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
it does because i cut it because for some reason it wasnt long enough .anyway when u try and solder a wire and it wont does that mean the wire useless?
j.hammond1
30
Oct 31, 2021 05:28 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Zoggon
Aug 10, 2015 10:39 AM
adriansaleem
Aug 1, 2015 09:28 PM
