Esc Cossie turbo boost issue
Old Jun 20, 2008 | 05:54 PM
baz_Ireland's Avatar
baz_Ireland
Default Esc Cossie turbo boost issue
Lads - Would a faulty Solonoid cause my esc cossie turbo to over - boost??
Cant seem to figure out with whats causing her to over boost.
Old Jun 20, 2008 | 07:49 PM
Steven_RW's Avatar
Steven_RW
Baz - what is " boosting too soon " ?
My owners of turbo cars couldn't be happy if their car came on boost just above idle.
Some more circumstancial details would help.
RW
Old Jun 20, 2008 | 08:41 PM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by baz_Ireland
Lads - Would a faulty Solonoid cause my esc cossie turbo to boost to soon??
Cant seem to figure out with whats causing the early boosting.
if you dont want your boosting early, i will
some more details would be handy fella
Old Jun 21, 2008 | 06:52 PM
baz_Ireland
sorry chaps will try again...
the turbo is over boosting - as in out of control etc.. she is reading 5 bar, previously it was at 1.5/2 bar.
when driving it there was a kicking back affect coming from the engine
we did a vacumn test on all the pipes - they were fine. the actuator is 6 months old (dont know if this is anything to do with it). we were thinking a faulty solenoid might be the problem - but we have no means of testing it etc.
what would be the common problems causing this
were told that we were lucky that we didnt blow the engine - then again this same chap is still to call and suss her out!
Old Jun 21, 2008 | 07:02 PM
foreigneRS's Avatar
foreigneRS
Testing the future
sounds possible - is it a small turbo escos with the Lektron valve?
the problem is that the wastegate is not opening for whatever reason. the actuator should open it, so could be a problem with that, but normally they give less boost rather than more - unless it or the wastegate is seized. if you put a pair of grips on the actuator rod, can you move it freely and open the wastegate? try also disconnecting the actuator rod and seeing if the wastegate rotates freely.
if all of that is working fine, it must be the boost control valve itself or the electrical supply to it.
Old Jun 21, 2008 | 07:09 PM
baz_Ireland
yes small turbo...
unsure of the valve..
my cossie mechanical mind aint the greatest!
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Escortdriver1
Jul 31, 2015 02:36 PM
