problem with peugeot 106 starting issues! advise.
Old Jun 19, 2008 | 11:54 AM
paceo's Avatar
paceo
Exclamation problem with peugeot 106 starting issues! advise.
my friends mum has a staring issue with the peugeot 106, it will start, run for a minute or so, or less and cut out, sometimes it will not start at all. is there a particular problem with these type of cars? its a S plate so i think its 1998?
i know all the hotspots to look for but if you know they have a common problem then please advise me please.
Old Jun 19, 2008 | 12:31 PM
paceo's Avatar
paceo
anyone? going there at 3 pm?
Old Jun 19, 2008 | 03:17 PM
Spax's Avatar
Spax
Coilpacks can play up
Old Jun 19, 2008 | 03:22 PM
paceo's Avatar
paceo
cheers mate, just got back
i have looked over the car today, cleaned the CPS, checked ht leads, spark plugs, coilpack has no splits and the ignition
now i must mention this problem is only from cold, so im thinking cold start has a problem? but where are they on these ugly motors?
Old Jun 20, 2008 | 12:18 PM
paceo's Avatar
paceo
Old Jun 20, 2008 | 05:00 PM
groomers's Avatar
groomers
the engine wiring loom can rub through on these from memory it is under the ns chassis leg at the front of the engine bay, may be this causing your probs?
Old Jun 20, 2008 | 05:55 PM
vinnyvangough's Avatar
vinnyvangough
For a start its a Peugeot!!!!! My mate says fuel pump!!!
Old Jun 20, 2008 | 06:09 PM
warleydaddy's Avatar
warleydaddy
just in front ofthe bulkhead on the N/S there is a big red button..Thats a fuel cut off.. Check wiring to that.. AND give it a few presses.. IF it clicks,then its set it self off for some reason..... Just a thought,as this happend on a Saxo i did...
Pete...
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
