BHP limit 4wd exhaust manifold
Old Jun 17, 2008 | 05:48 AM
Default BHP limit 4wd exhaust manifold
Thinking of swapping to a 4wd one for a bit earlier boost, anyone done this, good bad thoughts ideas welcome.
thanks
Old Jun 17, 2008 | 05:59 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
4x4 ex manifold gets restrictive over 450 bhp,and its hard to find one that hasnt cracked.
Old Jun 17, 2008 | 09:57 AM
stevecossy's Avatar
stevecossy
Graham goode says about 420bhp max for the 4x4 manifold, Mine not cracked yet and shes done 114k.
Old Jun 17, 2008 | 11:24 AM
I have one but it has a hairline crack in it, be ok though I would think, thanks for replies.
Old Jun 17, 2008 | 11:26 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
so to get boost earlier you want to use a manifold with a crack in it that will no doubt leak?
Old Jun 17, 2008 | 12:17 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Earlier boost is caused by more airflow.. considering a 2WD manifold flows more than a 4WD one, then I can't see how you're improving anything
Old Jun 17, 2008 | 12:20 PM
Chip's Avatar
Chip
Actually, they flow the same for any given flow from the engine
And far more to boost building than that, an unequal length setup can result in short durations of higher pressure within the turbine housing as two pulses hit at the same time which can be useful for spooling a turbo (although typically will be counter productive higher up the rev range) especially if tuned to happen just at the point before the turbo would spool anyway.
Id hope that when ford designed the manifold for the 4wd they took this into account.
Old Jun 17, 2008 | 02:56 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
I had 425hp & 425lb ft on my old Harvey engine on a 4wd manifold no probs & had seen 432hp with it !
I'd go with Lloyd on the prediction of hp figures & when the manifold becomes restrictive. It is slightly less laggy than the 2wd item & the hair line crack shouldn't matter too much, they all do & it's inside, not all the way through !
Good luck
jb
p.s. I prefer the sound of Cossie's wit a 4wd manifold !
Old Jun 18, 2008 | 12:20 AM
They have a much more compact design and offer less lag, as I drive a lot low down around 1500/2000 rpom this would suit me better.
I've never seen a problem with cracked ones actually breaking, or leaking to any degree that matters, so this is not a concern.
jessie_rs
62
Aug 6, 2019 09:27 PM
TPM961
Jan 15, 2018 10:50 AM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Si B
Sep 12, 2015 06:49 AM
Adam Graham
Sep 6, 2015 06:04 AM
