stage 3 boost ?
I was wondering how much boost i should be running at stage 3?
I have an rs500 intercooler and a t35 .63. when i had it set up it was just after the engine was rebuilt so they said I could turn it up after I had done 3000 miles but never did.
What should it be ?its at 19psi at the moment
We're running 25 peak, 22 held on our 2wd with a T34, greens and a 4x4 intercooler. Assuming your injectors are up to the job (and the fuel pump and rewired), you should be able to put a little more boost through seeing that you have an RS500 intercooler.
I asked Mark (MAD) to set it up on the safe side, was done in July on a hot day and we were getting early signs of det with a touch more boost than that so he wound the boost down, and a little more
Make sure you get someone in the know to set it up for you as you want it
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
