Wat psi should they be running?
Old Jun 12, 2008 | 10:38 PM
onzlow's Avatar
onzlow
Default Wat psi should they be running?
Hi i have just bought a s2 rs turbo told it was 190 bhp has adjustable boost aswell.Just wanted to no wat psi they should be running at low boost?
Old Jun 12, 2008 | 10:46 PM
NEWTON's Avatar
NEWTON
8_10 psi low boost
Old Jun 12, 2008 | 10:54 PM
onzlow's Avatar
onzlow
Thanks,and do you no what the boost guage should be sitting at when the car is idling?
Old Jun 12, 2008 | 11:03 PM
NEWTON's Avatar
NEWTON
-5 or somthink like that
Old Jun 13, 2008 | 12:51 AM
Micky's Avatar
Micky
0 psi if the car is on MFI.Regards,micky
Old Jun 13, 2008 | 08:25 AM
onzlow's Avatar
onzlow
Mine is sitting at -20?its a d reg so not sure what engine is in it?this is not right is it?what could be wrong.
Old Jun 13, 2008 | 08:27 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
What does the car being on MFI have to do with it pulling a vacuum on idle?
Old Jun 13, 2008 | 04:11 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
its fine to -20 on idle,theres no boost on idle so its sucking air in,hence pulling a vacuum
Old Jun 13, 2008 | 07:00 PM
onzlow's Avatar
onzlow
ok thanks
Old Jun 14, 2008 | 04:27 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
im sits at -10
Old Jun 14, 2008 | 06:58 PM
NEWTON's Avatar
NEWTON
get it set up
Old Jun 23, 2008 | 01:38 PM
onzlow's Avatar
onzlow
cool
dombanks
Sep 21, 2015 08:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
tib2220
Sep 14, 2015 12:33 PM
Marino
Sep 12, 2015 11:10 AM
