205 blocks
Old Feb 5, 2004 | 12:27 PM
Default 205 blocks
Right after much consideration i have come to ask myself this question. There is a 205 cosworth block and a 205 pinto block are these the same?
All ur help would be greatfull guys.
James
Old Feb 5, 2004 | 12:48 PM
PJay's Avatar
PJay
Yes and N, thay are of the same design but one is considerably stronger than the other.
Old Feb 5, 2004 | 01:00 PM
pjay, are they different castings? or are the cossy ones just selected blocks?
Old Feb 5, 2004 | 05:01 PM
Guinnless's Avatar
Guinnless
Exactly the same. No difference whatsoever. One's not stronger than the other.
HTH
Old Feb 5, 2004 | 09:39 PM
ffs so who's right then?
i was under the impression that they were from the same casting but they selected the best ones for the cossie!
Old Feb 5, 2004 | 11:11 PM
Mark_w's Avatar
Mark_w
the 205 block used in the cossie was picked from the transit engine line...the engines with the best bore grades were used....if you are reboring one of these then it does not make any difference
mark
Old Feb 5, 2004 | 11:25 PM
PJay's Avatar
PJay
Well if they are the same casting why are the cossie blocks and pintotransit blocks different?
Old Feb 6, 2004 | 06:42 AM
Guinnless's Avatar
Guinnless
They're not
If you are comparing later Transits then they had the 202 block which was introduced in 1992. Cosworth just picked the centre two bore grades (2 and 3) otherwise the casting is the same.
For info.
the numbers on the blocks is the capacity followed by the year of introduction.
205 - 2 litre/1985
202 - 2 litre/1992
200 - 2 litre/1990
Only the 200 block (and there's three different types ) was specially cast for the Cosworth 4x4 engine.
Old Feb 6, 2004 | 09:23 AM
PJay's Avatar
PJay
Why is it then that the transit/pinto block has '205' cast in a different size on the side of the block when compared to the '205' cast in the side of a cosworth block?
Old Feb 7, 2004 | 10:11 AM
Guinnless's Avatar
Guinnless
There may have been minor revisions depending on when the blocks were cast. Have you checked the part numbers?
Ford don't even list a 'Cosworth' block unless it's a 4x4 version. The T88 block has had the same part number from 1970 to Feb 1985 when it was revised and was given the 205 designation. Prior to this the 2.0 engines had 20 cast into the side of the block.
Until the 4x4 was introduced there was no 'Cosworth' block when referring to the YB engine.
HTH
Old Feb 7, 2004 | 10:51 AM
PJay's Avatar
PJay
Cool, learn something new everyday
Old Feb 7, 2004 | 01:39 PM
Guinnless were the fook do you get your info from?
Old Feb 7, 2004 | 07:57 PM
Guinnless's Avatar
Guinnless
Been running Pinto powered cars since 1985.
Which sadly means I'm old
PMSL
Old Feb 7, 2004 | 09:33 PM
bloody hell mate i was only 4 in 1985! you must be old!
Old Feb 8, 2004 | 09:02 AM
Guinnless's Avatar
Guinnless
There's no need to agree with me
No where's me Zimmer frame.
Old Feb 8, 2004 | 10:56 AM
well cheers guys for all that info. Now i can go home and steal my dads pinto engine out of his car and use it for my cossie! well the block ne way
James
Old Feb 8, 2004 | 11:29 AM
Jasu's Avatar
Jasu
I have -89 SaphCos where is 205 YBL block. Does anyone know what is YBL block?
Old Feb 8, 2004 | 11:49 AM
Old Feb 8, 2004 | 08:23 PM
Guinnless's Avatar
Guinnless
YBL is not a valid Cosworth Engineering drawing office code. A 1989 car should be YBB. Where are you reading the number from?
Old Feb 9, 2004 | 06:45 AM
Jasu's Avatar
Jasu
The YBL 443 code is in the correct place in front. Other numbers are:
17 D88
N5B
21030
205
85HM6015BB
Old Feb 9, 2004 | 10:52 AM
Guinnless's Avatar
Guinnless
Hmmm maybe it's one specific to your location to meet different emission requirements
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
