most common cause for?????
Old Jun 10, 2008 | 08:04 PM
picky775's Avatar
picky775
Default most common cause for?????
Whats the most common cause for wheel wobble at speed?? on the motorway today and gettin wheel wobble at between 65-70 would it just be wheels out of balance?? or could it be more problems ahead??
Old Jun 10, 2008 | 08:07 PM
BigChuck's Avatar
BigChuck
probably wheel balance
Old Jun 10, 2008 | 08:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Deffo wheel balance m8,mines doing the same,gettign mine sorted on thursday.
Old Jun 10, 2008 | 09:28 PM
TrevCos's Avatar
TrevCos
Loose nuts sir, no it's just the way I walk.
Old Jun 10, 2008 | 09:48 PM
Cem's Avatar
Cem
yep balance, if you got nice rims, try get stick on weights on, so they dont hammer the crap out of the bang weights puttin them on and chiping paint off the rim
Old Jun 10, 2008 | 11:40 PM
costina's Avatar
costina
Live long and prosper!!
wrong offset can cause problems
Old Jun 12, 2008 | 07:45 AM
picky775's Avatar
picky775
cheers for the replies guys
Old Jun 12, 2008 | 08:13 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
loose nut behind the wheel
Old Jun 12, 2008 | 08:33 AM
Dicko&Vacant's Avatar
Dicko&Vacant
lack of spigot rings in alloys can cause excessive wheel wobble too
Sarah
Old Jun 12, 2008 | 08:48 AM
cabbykarl's Avatar
cabbykarl
Like they say most likely simple wheel balance.
Knew mine wasn't as the whole car was shaking....turned out to be bent driveshafts, seen moving whilst running the car on the lift.
Solved by a quick n cheap visit to a local scrappy
Old Jun 12, 2008 | 09:38 AM
vinnyvangough's Avatar
vinnyvangough
Usually wheel balance or could be like mine and every wheel bent. Prob something to do with 5 people, 1 car and over 10 speedbumps at 50mph cause we were bored
Old Jun 12, 2008 | 10:00 AM
JamesH's Avatar
JamesH
Sarah
Or when they are used on the wrong application
I had HORRIBLE wheel wobble once, took me a few goes of taking all wheels off, getting them rebalanced and eventually noticed spigot rings squashed onto each bell!!
Old Jun 12, 2008 | 10:22 AM
ballin's Avatar
ballin
how cool
Old Jun 12, 2008 | 10:43 AM
Sonic Boom's Avatar
Sonic Boom
Horribley Buggered Tyres as well will have your fillings shaking out.
What happens when you wear a set of tyres out on a track day and think "Ye i'm sure they will ok to get home on!!!"
Old Jun 12, 2008 | 11:40 AM
Dicko&Vacant
if you get a bleb that causes some nasty vibration mind
Neil Clark
21
Oct 1, 2015 07:02 PM
hopper350
Sep 4, 2015 12:53 AM
muffster
13
Sep 3, 2015 09:40 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
