Racing Plugs
Old Jun 10, 2008 | 04:23 PM
Smoker's Avatar
Smoker
Talking Racing Plugs
I am currently working with denso motorsport division to develop a racing plug for the yb engine,on cars that are pushing over the 400 bhp mark.derived from the iridium genere,but wont be as fragile as the standard ik range,those of you who might be intrested in getting your hands on these pm me and if enough intrest is generated i might just set them into production for the passionford crew!
Old Jun 10, 2008 | 04:27 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
wouldn't think people will buy them before they have been tested..........
Old Jun 10, 2008 | 04:31 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Sounds interesting.. what are your credentials to enable you to successfully co-develop a plug?
Old Jun 10, 2008 | 04:43 PM
Smoker's Avatar
Smoker
Thumbs up
having worked with ngk and denso techincal for the last 10 years gives me the knowledge to "help" spec a plug which would give optimum performance over the currently available plugs on the market,also i am sacrificing my 500bhp engine to help with development,so i hope that that should suffice your concerns.
Old Jun 10, 2008 | 04:59 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Excellent
Out of interest, what problems have you come across in the past with doing similar stuff?
Old Jun 11, 2008 | 11:21 AM
Smoker's Avatar
Smoker
Talking
the most common problem we have come across using the standard platinum and iridium plugs is the breaking of the tips = engine failure! also the blow out of the spark = det.
The racing plugs will have the centre electrode seated inside the housing,which remedies both causes!
This is a must for all those of you who want optimum power delivery and have paid good money for your engine rebuilds and most importantly for those who do track day their cars.
Now ready and developed!!!!!!!!!!!!!
Also available for other cars mail me application and i will be happy to help.thanks.
Old Jun 11, 2008 | 11:36 AM
nickscunny's Avatar
nickscunny
wish i knew that before i bought them for my zetec cab and rs2000.....
engine failure due to breakage of tips???
Old Jun 11, 2008 | 12:12 PM
RS Juto's Avatar
RS Juto
Sound intresting, however what are the reasons regarding over 400bhp. Im running about 350 surely it would do any harm to run them on lesser bhp cars. Just a thought, might open the offer up to more takers.
Old Jun 12, 2008 | 02:02 PM
Smoker's Avatar
Smoker
Default cossy power!!!
breaking of the tips means no spark = melted piston!
The plugs would be ideal for cars with 300+ bhp due to the heat range.
This technology has been long awaited and works wonders on the yb,giving much improved throttle response and may even increase mpg.
Old Jun 12, 2008 | 08:08 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Improved throttle response from a spark plug? C'mon, I think marketing bullshit is taking over now
Old Jun 13, 2008 | 11:39 AM
Smoker's Avatar
Smoker
Default no gimmick!
better ignition=greater combustion=more power! there are scientific formulas to prove it all mate! F1 technology for your road car,those who are in the know understand it all.
Old Jun 13, 2008 | 12:09 PM
Stu @ M Developments's Avatar
PassionFords Creator
I know a little about ignition and fail to see how moving the point of ignition away from the centre of the combustion chamber is going to result in better flame propegation and I for one am very interested to read your theories on this.
Electrode shrouding is done for a few reasons, and all to my knowledge are to do with reliability at high engine speeds and power, not quality of burn, as the plug electrode wants to be as near to the propegation Kernel as possible in order to maximise energy release and thus efficiency from the fuel available in that cycle.
Old Jun 13, 2008 | 02:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
that doesn't sound like a term that an expert in spark plug technology would use to me
Old Jun 13, 2008 | 02:46 PM
I wonder if people genuinely think its like a candle and it gets "Blown out"? Surely not?!
Old Jun 13, 2008 | 08:48 PM
nickscunny's Avatar
nickscunny
im more worried incase the tips break, both my rs2000 and my zetec cabriolet are running on denso plugs.....
Old Jun 14, 2008 | 10:57 AM
Smoker's Avatar
Smoker
Talking
The blow out of the spark was reffering to the standard platinum and irridium plugs whose tips tend to break as these precious metals are very fragile.As stu mention these plugs are designed for racing as the title suggests! where the advantage comes in to effect is that the electrode and tip are precious metals which conduct far superior than that of copper core,thus increasing spark output by using a finer point to create the spark.
Old Jul 19, 2008 | 12:19 PM
Any reply to this?
Old Jul 21, 2008 | 08:03 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Sounds like snake oil to me
Old Jul 21, 2008 | 08:19 AM
cossie500's Avatar
cossie500
To Queef is not right
Just put the denso ik31's in my stage 3 sapph, dont want any engine failure, is the tip breakage common?
Ive had to adjust them already as the spark was getting blown out at 0.65mm, now set to 0.6mm with no problems.
Old Jul 21, 2008 | 08:21 AM
RWD_cossie_wil
The spark does not get blown out, the resistance of the air/fuel ratio is too high for the spark to cross
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
