Rewiring fuel pump
One of the issues mentioned at the set-up at MSD was the voltage drop at the pump.
I've been told to cure this i need to run a fresh lead/wire from the back of the fuse box to the pump and a fresh earth is this all that needs doing?? and what thickness is currect for the amount of voltage needed??
Thanks
Thanks
If done correctly, and it is hard not to!!, they will be more reliable than ford wiring which can be up to 21 years old so does well anyway!!
If it were me I would run a new live wire/relay from the front to rear for the live, using original wire as trigger for said relay, then earth the pump inside the car somewhere at the rear as there is plenty of areas to get a good earth here, even if it means drilling a hole and using nut and bolt to hold terminal, as it can be easily hidden.
One thing Tab, is i looked through loads of threads and alot say different types of wire which do i go for as i'll pick some up from work tonight
Cheers pal
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
