mk1 escort breaking all parts available, including 4x4 cossie engine
sierra cosworth 4x4 engine, just going through a complete engine rebuild, due to crank letting go. its at stage 3 and t34 and greens etc cost £2000 in parts will take £1500 ovno
also available is
an alcon 6 paddle clutch and pressure plate only covered 100 miles at most
t5 gearbox
a jenson axel built by john sharpe engineering to cope with 500bhp, its got a lsd etc cost £2000 to build, again only covered 100 or so miles.
2.8i grp4 bilstein front struts.
rear gaz coilovers to suite turreted car
alloy shaped fuel tank with built in swirlpot
bias pedal box with hydraulic clutch
brand new OMP 6 point bolt in roll cage. unpainted still
2 15x8j and 2 15x7j superlight wheels with very good toyo tyres
radtec radiator and intercooler setup with electric fans. good condition.
also a strut brace, the big square shaped type.
if there is any other things you might need please contact me on
07792862615 or shauncambell@msn.com thanks shaun.
also available is
t5 gearbox
Hi mate
How much for the lot? But without the car? I just want everything as i've got a mk1 2 door sport. Was going to buy a complete Sapphire 2wd in and break it again but if you have the bits i can buy the lot.
thanks
John
thanks
John
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
