Uce small turbo!!!
Old May 30, 2008 | 01:18 PM
Bugarin's Avatar
Bugarin
Question Uce small turbo!!!
Hello.
what is the diferent between ANTY and COSY small turbo´s ecu, and, why my small turbo(that have a ANTY ecu) don´t work with a COSY one??
Are the chips diferents too??
Thanks.
Old May 30, 2008 | 01:28 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Because the ECU is encoded to talk to the PACS system, so you have to get this set up at your local Ford dealer. However, I understand that you have to have the same serial code for this to be changed, as in you must replace a COSY ECU with another COSY ECU and then get Ford to recode the PACS to the new ECU, otherwise it will not disengage the imobiliser circuitry.
Old May 30, 2008 | 04:44 PM
cosmagedon's Avatar
cosmagedon
I thought it was PATS? Passive Anti Theft System? Not PACS. Correct me if im wrong.
Old May 30, 2008 | 05:10 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
maybe it's Passive Anti Cunt System?
Old May 30, 2008 | 05:14 PM
cosmo V6's Avatar
cosmo V6
no need for correcting you as your right
Old May 30, 2008 | 05:22 PM
The Youth.'s Avatar
The Youth.
my small turbo doesn't have the pats system...
it has the wanky wipac one
steve
Old May 30, 2008 | 07:26 PM
cosmagedon's Avatar
cosmagedon
Whats wipac? never heard of that?
Old May 30, 2008 | 09:33 PM
MarkN's Avatar
MarkN
Its a dodgy factory fitted immobiliser with an electronic key in the centre console. When they go wrong they tend to immobilise the car permenantly...
Old Jun 1, 2008 | 01:18 PM
sailorbob's Avatar
sailorbob
There is only a small difference in programming between the COSY and ANTI ecu's. The COSY ecu coding has an error in it that causes the initial (on power up) copying of variables into ram to fail. The later ANTI ecu fixed this problem.
Old Jun 2, 2008 | 08:14 AM
Mike Rainbird
Caraholic
Sorry, I meant PATS .
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
