Uce small turbo!!!
Uce small turbo!!!
Hello.
what is the diferent between ANTY and COSY small turbo´s ecu, and, why my small turbo(that have a ANTY ecu) don´t work with a COSY one??
Are the chips diferents too??
Thanks.
Thanks.
Caraholic
Because the ECU is encoded to talk to the PACS system, so you have to get this set up at your local Ford dealer. However, I understand that you have to have the same serial code for this to be changed, as in you must replace a COSY ECU with another COSY ECU and then get Ford to recode the PACS to the new ECU, otherwise it will not disengage the imobiliser circuitry.
There is only a small difference in programming between the COSY and ANTI ecu's. The COSY ecu coding has an error in it that causes the initial (on power up) copying of variables into ram to fail. The later ANTI ecu fixed this problem.
Matt Baxter
16-09-2015 08:30 PM
