rad????
where is the best place to get a new rad or get mine fixed i am from birmingham so the closer the better unless they post. i have a front mount so need the type with the fixings adapted to suit
thanks
thanks
if yours is repairable and in general good nick i.e. not to rusty you in yellow pages or something like that to see if there is anyone around you that can fix yours if you get it done get it re-cored with a copper core lods more effictive than even the alloy ones.
Whilst copper is a better heat dissipater, it is not as good when faced with flying stones etc.
ps I will have a recored one going in about a week, but only cost around Ł70 for recore, don't generally advertise stuff, I just bin it a sit is easier, can't stand the people who try to give you stupid money for it, get more pleasure out of denying them something stupidly cheap!!
Hi All, I noticed that someone is saying that copper is better at dissipating heat than Alloy. Copper is a better heat Conductor than alloy but when it comes to dissipating heat, Alloy is better because it is lighter than copper so will not store the energy as much as copper.
True but when you add in air flow it changes, as copper conducts the heat to the air better, yes it is denser and has more mass, but is also MUCH stronger than alloy, a point worth considering when being subjected to debris on the road.
liamT74
Sep 23, 2015 10:24 PM
