Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Audi A3 - Help needed desperatly please.
Old May 23, 2008 | 12:08 PM
carla5's Avatar
carla5
Default Audi A3 - Help needed desperatly please.
Hi,
I own a Mk6 Escort Si and have found this forum really helpfull in the past...
I knw it's not a FORD but would be really greatfull for some help on a mates car, he's got a W reg Audi A3 65,000miles that has just gone in for the MOT, the mechanic has just told him he needs a new engine as it has faied on his emisions, I found this totally bollocks infomation, the car drives stop on doesn't use any oil water and for 65,000 miles on an Audi I just find it very hard to believe.
Before he sells his arse tonight in the local cottaging club can anyone help with what he could possibly do before replacing the engine??
He did say it needs a godd service???
Many thanks in advance.
Old May 23, 2008 | 01:28 PM
If the engine is running ok, then massively unlikely to be that!!
I would do a complete service on it, firstly, then take it for a CO check, thsi will give a VERY big clue as to what is wrong.
The most likely thing is a duff sensor like the lambda.
Put up what the readings were.
Old May 23, 2008 | 05:05 PM
pani_k's Avatar
pani_k
PassionFORD Member
As above. Really unlikely to be the engine in fact 90% sure it probably isn't as you'd definitely know if that was going to give up and it would be chucking out blue/black smoke and stinking of fuel as well.
Most likely to be failed lambda sensor or possibly knackered cat but definitely not something like a duff engine!
Old May 24, 2008 | 09:24 AM
grayzo's Avatar
grayzo
grayzo
as above mate the m.o.t tester sounds like a bit of a idiot
Old May 24, 2008 | 09:27 AM
RichieST's Avatar
RichieST
what did it fail on? CO or HC's?
Old May 28, 2008 | 11:55 AM
carla5's Avatar
carla5
Default Audi A3 problems
Thanks for the comments people, below is a list of what was on the failure sheet;
Its all on the refusal certificate I have no graphs or anything they haven’t given me them
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.2b)
Exhaust emissions hydrocarbon content after 2nd fast idle excessive
Exhaust emissions lambda reading after 2nd fast idle outside specified limits
Exhaust emissions carbon monoxide content at idle excessive
So they basically told me head gasket had gone but then it changed to the engine block had cracked etc
Any help would be greatly appricated
Thanks again
Old May 28, 2008 | 11:59 AM
T3ORA's Avatar
T3ORA
Thanks again
more like the lamba has failed
Old May 28, 2008 | 12:14 PM
Nash_mr2's Avatar
Nash_mr2
lambda or the Air Flow Meter - or both.
very doubtful it's the engine itself.
also check the CAT see if thats ok - if it's collapsed that will cause an emissions failure
Old May 28, 2008 | 12:35 PM
RichieST's Avatar
RichieST
see if your mate can get it to another garage for a second opinion, get them to stick the probe up it and see if its getting similar readings.
I would also suggest the lambda sensor is buggered!
Old Jun 1, 2008 | 02:46 PM
MattyRST's Avatar
MattyRST
Dont Golfs/Audi suffer from a failed MAF sensor ???
Old Jun 6, 2008 | 08:17 AM
carla5's Avatar
carla5
Hi people
Lambda Sensor failed and it was given a good service and wne tstraight through emmisions - you guys are great and saved my mate loads of money, many many thanks to everyone who helped.
Mates has asked one last request he says the service light is on still it says "Inspect" next to mileometer and has asked if anyone knew how to fix this so it didn't show??
Thanks again for the help
Old Jun 6, 2008 | 11:48 AM
RichieST's Avatar
RichieST
http://www.honestjohn.co.uk/forum/po...tm?f=4&t=21393
have a read through here, there's a few different methods
JoeyBoyden
Jan 4, 2024 02:36 PM
cos elle
Sep 1, 2015 06:48 PM
cameron2
Aug 19, 2015 11:49 AM
M K
Aug 12, 2015 06:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
