Is 330mm the biggest with AP 4 pots??
Old Feb 4, 2004 | 12:00 AM
kjc300's Avatar
kjc300
Default Is 330mm the biggest with AP 4 pots??
As above, or can you get brackets made up for bigger discs??
Old Feb 4, 2004 | 09:39 AM
The size of the disc is governed by the radius in the back face of the caliper, if you fit a larger bracket to space the caliper out you will end up with the pad overhanging the disc and/or the outer edge of the dics touching the caliper.
I used to have 356x32mm discs with 4 pot AP's, but I had to get these the calipers machined by AP Racing in order to do this.
Most of the CP5000 range calipers (the black calipers with dust seals) take a Max disc size of 330mm.
Andrew
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Bailes1992
Sep 19, 2015 02:17 PM
Minirotty
11
Sep 15, 2015 10:16 PM
