rs1800 wet weather rough running
Old May 17, 2008 | 03:41 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default rs1800 wet weather rough running
Hi
By rs1800 has started playing up recently in wet weather. When starting in wet weather its rough as a dog occasionally misfiring and sometimes stalling when you nail the throttle in an attempt to force it throught the rough patch.
Initially i reckoned it to be the MAF sensor playing up and i replaced it with a new one i had spare which totally cured the problem.
Except its come back again after 2000 trouble free miles!!!
Exactly same symptoms and problem started as soon as it was wet.
My engine is fed by an in engine bay cone filter unshrouded (i didnt fit it) and is a basic 2.0 zetec conversion with magnex exhaust system (and sports cat).
Its had plugs, leads, coil pack, and hego all in last 6 months as well as the maf i changed.
The only theory i can come up with is maybe excess spray in engine bay meaning a wet filter and lots of water vapour into the engine screwing up MAF sensor readings. The filter is under the RS bonnet vent so may get wet when stationary explaining the fact the running problems from start up rather than just road spray.
Any body experienced this?? is my theory in the right ball park??
Old May 17, 2008 | 07:15 AM
A lot more likely to be water getting into a connector somewhere, why not cover the vent with tape till it rains again and see if it helps, but as said almost defo a bad connection, that is getting soaked causing it.
Old May 17, 2008 | 07:27 AM
mentalasanything's Avatar
mentalasanything
If it does it again, remove the MAF sensor connector, spray the connector and the plug with WD40 and connect them back up, see if it does it again.
Lee
Old May 17, 2008 | 11:25 PM
Psycho Warren
Carbon Crazy
cheers dudes will try that!!
jessie_rs
62
Aug 6, 2019 09:27 PM
xrmalin
Sep 13, 2015 06:52 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
