Feista Gearbox Bearings
Old May 7, 2008 | 06:11 AM
bettz's Avatar
bettz
Default Feista Gearbox Bearings
Hi guys my fiesta was making a wurring noise which STOPPED when i pressed the clutch in but you could hear it when the clutch wasn't pressed i took it to a mechanic & he said the gearbox bearings needed doing so i've just had them done & was wondering if they should still be making the same noise the mechanic said they'd sound loud for another 1000 miles or so any help?
Old May 7, 2008 | 06:37 AM
iansoutham's Avatar
iansoutham
OCD Victim
Sounds like you have been had.
I would have said clutch release bearing is the noise, not gearbox (assuming he means input shaft bearing).
And no, something will not make a noise after being fixed if the problem was a noise in the 1st place.
Old May 7, 2008 | 07:05 AM
bettz's Avatar
bettz
Yes he said the Input Shaft Bearing & Layshaft Bearing needed fixing as it was making a noise when the clutch wasn't pressed he said there quite common in fords hes never ripped me off before had photos to prove he'd done the work aswell as he did car on warrenty and had to email pics to garage as proof
mjonathan24
Oct 29, 2015 10:39 PM
89barto89
Oct 4, 2015 06:59 PM
Iain Mac
Sep 30, 2015 09:39 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
