wots the best polish 2 use
Old May 3, 2008 | 08:10 AM
sean2k's Avatar
sean2k
Default wots the best polish 2 use
can any off u guys help me wots the best polish u can use on cars i want sumthing easy 2 put on and take off
Old May 3, 2008 | 08:14 AM
joffy's Avatar
joffy
SLOW LEARNER
in fear of gettin slated compared to the new polishes im still gonna say autoglym super resin polish, but then im not exactly a bufty
Old May 3, 2008 | 08:44 AM
justin j's Avatar
justin j
poorboys or cleakote stuff been using them for a while its good stuff easy on and off and lasts for ages got my stuff from here with great service
http://www.detailedobsession.com/catalog/index.php
here good results from the dodo stuff which il go for when i run out ov my other stuff
Old May 3, 2008 | 03:37 PM
sean2k's Avatar
sean2k
thanks i will keep that in mind i am new 2 the ford game my mate has a 40k on the clock 3 dr cossie i just want 2 mre bout them like the diffence between 3dr and rs500 ect and other info cheers sean2k
Old May 3, 2008 | 03:54 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
ive found that a couple of local polish lads are the best to use as they will get it gleaming like a mirror for a couple of shiny buttons or i refuse to pay them . no effort at all on my part.
Old May 3, 2008 | 06:23 PM
C4llyT's Avatar
C4llyT
You mean polish or wax/sealant?
Old May 3, 2008 | 08:33 PM
sean2k's Avatar
sean2k
wots the diffence in all 3 of them? wots best 4 dark and light colours and wot the best companys 2 use? i am just wiv it all cheers sean2k
Old May 3, 2008 | 09:14 PM
C4llyT's Avatar
C4llyT
What colour is it?
Basics is cut polish and wax (or sealant, both are LSP - last stage product, for protection and shine).
Keeping it simple you'd get something like t-cut or autoglym paint renovator for cutting, then a polish like autoglym super resin polish, then a wax or sealant, depending on colour and what finish you want.
Old May 8, 2008 | 05:47 PM
sean2k's Avatar
sean2k
thank u very much 4 that they r loads of differnt gear on the market it just gets 2 a bit hard 2 pick the right 1 4 the car i just want that wet look really its an orange car
Old May 8, 2008 | 06:32 PM
C4llyT's Avatar
C4llyT
Depends how deep you want to get into it...
Megs stage 1 and 2, or mentioned above, then say Victoria concours - Ł30 for a decent enough sized tub.
This lasts a long time and gives awesome results.
Is more cost effective than cheap waxes.
To help the polishing and application of wax, use a german pad.
Can find it all on cleanyourcar.co.uk and a few others.
Edit/ Before all that you want to use a clay bar on it, something like sonus green.
Old May 8, 2008 | 08:57 PM
Mike C's Avatar
Mike C
The Special One
I'd suggest you give Poorboys Natty's Paste Wax (normal for light cars, blue for medium and dark cars) on top of Collonite a try
That's not "hardcore bufty" territory, but will give you much better results than the run-of-the-mill stuff
You could just use the Poorboys and see how you get on as it's a really good shine, but not very long-lasting. The Collonite, however, is very durable, but not such a nice shine. You can combine the 2
Old May 8, 2008 | 09:08 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Agreed, i usually follow collinite with natty paste wax.
For polishing by hand i'd recommend Poorboys Polish with Sealant, it's very easy to apply and very easy to take off leaving no residue.....applying with a machine will remove light scratches and trails
Old May 8, 2008 | 09:16 PM
KSA-Cossie's Avatar
KSA-Cossie
Smells nice to.
Old May 8, 2008 | 11:43 PM
STUCOS's Avatar
STUCOS
black diamond wet look polish
cheeRS stu
Old May 9, 2008 | 12:45 PM
C4llyT's Avatar
C4llyT
Blackfire:
Old May 9, 2008 | 05:50 PM
sean2k's Avatar
sean2k
cheers lads the bmw looks clean wots that u use on that mate by the sounds off it i can spend load of coin on cleaning gear 4 my car then cheers sean2k
Old May 9, 2008 | 06:05 PM
C4llyT's Avatar
C4llyT
That was after machine polishing to remove all the swirls and scratches.
You could happily spend Ł500+ on gear, always something you want/need.
Best way to assess yours is clean it, and at night take it down the petrol station under the halogens, is a fucker for showing the defects.
This is the sort of thing, although this was a bad one, needed wet sanding:
Afterwards you'll end up with paint like this:
I think before anything you need to see how bad the paint is, and decide how much time/money/effort you want to spend on it, and what finish you require, or will settle for.
Here's a couple before and after pics, even relatively new cars are often swirled and scratched to fuck, if you catch them in the right light:
Old May 15, 2008 | 07:13 PM
sean2k's Avatar
sean2k
the bmw is clean wot do u use on that?
Old May 16, 2008 | 02:27 PM
C4llyT's Avatar
C4llyT
That's PolishedBliss's work, and Zymol Vintage.
http://www.bmwowner.com/forum/viewto...?f=36&t=121179
Old May 16, 2008 | 08:44 PM
sean2k's Avatar
sean2k
wots that when its at home?
steve.rst
Mar 15, 2016 08:01 AM
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
Marino
Sep 12, 2015 11:10 AM
