T34 boost
Old May 1, 2008 | 05:35 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default T34 boost
What is max boost a T34 .48 will do? thanks
Old May 1, 2008 | 05:49 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
what injectors would help a bit.....ie ur 803's will hold 22/23 psi.........but bigger will hold more.....but a t34.48 is good for a 30/32psi spike and a held 28.........(how long it lasts...???..)
Old May 1, 2008 | 05:56 PM
RS LOZWORTH
im running 803's , T34, 500 cooler, breather kit, swirl pot ,group A filter, 3 mar map etc, curently peaking at 24psi, holding 21 at 333bhp im just intested what is max psi for my turbo
Old May 1, 2008 | 06:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Ran my 803's at 28 psi no probs.
Old May 1, 2008 | 06:25 PM
RS LOZWORTH
gd gd cus im hoping to run 29 and hold 24/25 but is that right on the limit for turbo/injectors?
Old May 1, 2008 | 06:28 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine weren't totally maxed out but i didn't want to go any higher m8.
Old May 1, 2008 | 06:45 PM
pete mcrash
...................but ur on about PEAK..........they wont hold it..
Old May 1, 2008 | 06:47 PM
pete mcrash
....i'd never advise anyone to go greens t34 and over 22/23 held.................bang....mine did at 23psi.......
Old May 1, 2008 | 06:49 PM
KSA-Cossie's Avatar
KSA-Cossie
Aye sorry peter,they held 25 psi no bother.
Old May 1, 2008 | 06:51 PM
RS LOZWORTH
what went bang?
Old May 1, 2008 | 06:55 PM
pete mcrash
my engine.........................and my pals at 23 psi on 803's...........on a t34.48........every tuner i've used has always said no more than 23psi........
Old May 1, 2008 | 06:56 PM
KSA-Cossie's Avatar
KSA-Cossie
Im guessing his engine m8.
Old May 2, 2008 | 04:24 PM
Simmo's Avatar
Simmo
That's exactly how my old one was set up with the same spec, although it had to tail off to 20psi for the limiter, the 803s being the limiting factor (the pump was re-wired too!).
Old May 2, 2008 | 04:31 PM
lamb chops's Avatar
lamb chops
You set the boost level to what your engine will run without running lean or pinking.. This could be 29 psi 21 psi or whatever. A professional tuner will set this for you job done, i would never just set the boost and "hope" its ok.
diffent injectors will flow at diffrent rates plus a host of other variables to consider, fuel pressure, fuel flow from the tank etc etc
Old May 2, 2008 | 04:58 PM
LHD220Turbo's Avatar
LHD220Turbo
i will be running t34.55, siemens blacks 55lb, 500 cooler, standard motor, 3 map bar, MSD chip and i've been told it will peak 28psi and hold around 24psi
Old May 2, 2008 | 05:18 PM
BigErn's Avatar
BigErn
36psi spike, 30-32psi held, greys, low comp, 8250 rpm. (Not my car)
It killed 3 turbos last year.
Old May 2, 2008 | 10:06 PM
mechanic28's Avatar
mechanic28
but thats got some mid range punch!
Old May 3, 2008 | 12:27 AM
BigErn's Avatar
BigErn
Its great fun on the twisty A and B roads with its combination of revs and boost, as long as you keep it on song it fuckin flies.
Old May 4, 2008 | 05:48 PM
Yura's Avatar
Yura
hmmm.... another question to all: what AFR do you have at full boost with t34.48 and 803's or what AFR is good for this spec by your opinion at 98 RON and std comp. ratio?
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
