s2 fuel pump relay bridging
Old Apr 24, 2008 | 08:51 PM
RScrew69's Avatar
RScrew69
Default s2 fuel pump relay bridging
does anyone know what pin numbers you have to bridge together to put your fuel pump on constant and to make sure your relay and pump are working?
cheers in advance
Old Apr 24, 2008 | 09:16 PM
rst230bhp's Avatar
rst230bhp
Pin 30 and pin 87
Old Apr 25, 2008 | 09:18 PM
Bubs's Avatar
Bubs
you can also just pop it open and hold the swith closed. thats cheating tho.
Old Apr 25, 2008 | 10:33 PM
RScrew69's Avatar
RScrew69
the s2 pink relay does not have 87 on it. i have 30
Old Apr 26, 2008 | 04:20 AM
It should be as said above.
87 is the std DIN format for OUTPUT, from a relay.
What numbers do you have ?
Old Apr 26, 2008 | 09:14 AM
rapidonion's Avatar
rapidonion
Default relay
or you could just use a green relay out of a zetec fuse box it works fine ive used one before.
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
