zetec injectors on cvh rail?
im just about to zvh an xr3i and run it na but i was wondering if the zetec injectors will mount to the cvh rail or what, anyone have a clue?
sorry to state the obvious here but if your keeping it N/A and not using throttle bodies or big carbs why on earth are you doing a zvh!??
better to use the whole zetec unit, cheaper as you dont have to mess around with blocking off oil ways for a start and you can use the original EFI setup which if its a high spec 1.8 will see you with just under 130php whereas i cant really see a cvh 8v head giving you anywhere near that. the only reason i can see why you would want to do a n/a zvh is that the manifolds for throttle bodies and carbs are easier to come by or you want to keep the engine looking kinda stadard but have a bottom end?
thanks for the advice the only reason im doing it this way is 3 people wh have fitted full zetecs in their mk4s have said its not worth the hasstle might as well just have the bottom end but now i aint 2 sure
less work to do the full conversion mate. if the car was originall on carbs then yeah you have to put in a electric fuel pump and a tank with a swirl pot but as you have an xr3i its allready there.
wiring is a doddle for it. check out www.s2rs.co.uk and in the how to bits there is a section my mate put up on it
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
