s2 not boosting but making all the right noises?!
Old Apr 22, 2008 | 07:30 PM
rscombi.'s Avatar
rscombi.
Default s2 not boosting but making all the right noises?!
i drove my rs combi van up to the pod this weekend, bout 140 miles, drove perfect all the way up, as soon as i pulled in and bought my ticket, i pulled away and the combi wouldnt go anywhere! its boosting and holding 15psi, not splutering, turbos spinning up nice, basicly its making all the right noises just wont go, it drove the 140miles home fine to! apart from not being able to usethe turbo! HELP ANY1! mayb a sticky actuator?
Old Apr 22, 2008 | 11:25 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you got a dump valve on there if you have check that aint fucked or that you aint got an air leak somewhere
Old Apr 23, 2008 | 09:29 PM
Joe1199's Avatar
Joe1199
check actuator bolt/thread sounds like your wastegate is jammed open although if its making the boost maybe a boost pipe has come loose?
Old Apr 24, 2008 | 12:42 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Old Apr 24, 2008 | 12:52 PM
pani_k's Avatar
pani_k
PassionFORD Member
I'm guessing the turbo is spinning up but its not using the boost. Actuator I would have though sticking.
Old Apr 24, 2008 | 07:11 PM
rscombi.'s Avatar
rscombi.
didint make myself clear , its not goin when it should. hence, "not boostin" bu the boost gauge tels me im boostin an holdin at 15psi as usual,
Old Apr 24, 2008 | 07:13 PM
rscombi.'s Avatar
rscombi.
dump valve is fine, no hoses off, that was the 1st thing i checked, fuel regulator?
Old Apr 25, 2008 | 03:42 PM
pani_k's Avatar
pani_k
PassionFORD Member
my mates evo had the same symptoms and was sticky actuator. boost would come in but the car would rev and not go anywhere.
Old Apr 25, 2008 | 04:25 PM
rscombi.'s Avatar
rscombi.
cheers people gonna have a butchers this wknd but keep the advice coming just in case its not the actuator,
Old Apr 25, 2008 | 06:02 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
cracked exhaust housing?
Old Apr 27, 2008 | 05:00 PM
SafeChav's Avatar
SafeChav
If the turbo is producing and holding 15 psi of boost it has to be something to do with the engine management.
TPS would be my first port of call seeing as they are prone to dry joints internally, and this being the sole component that triggers your full load fuel enrichment.........
Old Apr 28, 2008 | 10:12 AM
GUZZLER's Avatar
GUZZLER
if it has a knock sensor it could be the ecu at fault, will boost like normal but the ecu could be taking the timing away, will make all the noise but feel flat.
Old Apr 28, 2008 | 02:23 PM
rscombi.'s Avatar
rscombi.
yea thats what its doin mate, also not startin now, fuel regulator ecu?
Old Apr 29, 2008 | 05:15 PM
SafeChav's Avatar
SafeChav
you need to identify whats missing from the equation before you can begin fault finding.
Fuel? Spark?
Old Apr 30, 2008 | 07:30 PM
rscombi.'s Avatar
rscombi.
turning over now, it wants to but just wont. stinks of fuel also
Old Apr 30, 2008 | 08:03 PM
Moose's Avatar
Moose
my fuel ecu fuse had blown, was an arse to start when cold and when boost came in it dint do anything, maybe worth a look
Old May 1, 2008 | 07:31 AM
instain's Avatar
instain
how bright is the spark also
Old May 1, 2008 | 06:04 PM
bamba's Avatar
bamba
just a thought have you checked the timing,just too see if the belts jumped a tooth.rare i know but worth a check.
Old May 1, 2008 | 11:13 PM
pani_k's Avatar
pani_k
PassionFORD Member
cant be actuator then or duff turbo wastegate i wouldnt have thought because these wouldnt correlate to a starting issue unless this is of course another issue its picked up
Old May 3, 2008 | 02:30 PM
rscombi.'s Avatar
rscombi.
got it goin!it was 5th injector, stil not boostin tho so checked the fuel pump relay, its melted! any1 got 1?
Old May 3, 2008 | 02:38 PM
SafeChav's Avatar
SafeChav
if the fuel pump relay wasnt working the car wouldnt run so dont think for a minute thats going to solve your boosting issue.
I will almost guarantee you need a new fuel pump aswell, that'll be whats made the relay melt.
Old May 3, 2008 | 06:23 PM
rscombi.'s Avatar
rscombi.
well that cant be helpin the situation surely!! gona change that1st, process of elimination right?
Old May 3, 2008 | 08:07 PM
orionowl's Avatar
orionowl
Smile
got a relay mate pm your address and ill post tusday dont worry about payment hope it helps
Old May 7, 2008 | 09:47 AM
SafeChav's Avatar
SafeChav
if its working its working.....if it wasnt the fuel pump wouldnt run and therefore it wouldnt start.
if i had any doubt as to the relay being a symptom in the problem i would advise changing it, and as ive already said, your current one is getting hot and melting, unless you change the fuel pump aswell the new one you fit will do the same thing..........
Old May 19, 2008 | 06:19 PM
rscombi.'s Avatar
rscombi.
thanks 4 all your help guys but no1 was right!! got it back 2day and the timing was way out, the distributor had worked its way loose, so all back running sweet as now, cheers!!
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
