boost
Old Apr 21, 2008 | 12:57 PM
capri280's Avatar
capri280
Default boost
Had my cossie set up by stu about 8months ago
I fitted a brand new turbo technics t35 0.55 housing and actuator
i have had it out about 8times and put about 500 miles on it
when set up stu had it set up with 29psi to give 380-390bhp
I had it rolling roaded on the 15march and recored 335.9bhp and 377lbft torque which was a bit down on expectations
I had it out for a run at the weekend and notice that it is only recording 24psi on the gauge and i now think this is why it may have been down on power
Am i right to assume to the actuator has been bedding in and therefore the psi put out has dropped
Would i be right in also adjusting the actuator up to give the reading of 29psi as set up by stu
Old Apr 21, 2008 | 01:03 PM
costina's Avatar
costina
Live long and prosper!!
Was the figure at the wheels if so thats near just a little down on a 2wd set up
I'd put a little more preload and test keep doing it untill u get what u need also check hoses for a boost leak
Paul
Old Apr 21, 2008 | 01:19 PM
capri280's Avatar
capri280
Default car
figures at the fly wheel
when you say preload you mean tighten the actuator to increase the boost that the actuator will hold before dumping to the exhaust
Old Apr 22, 2008 | 08:53 AM
capri280's Avatar
capri280
Default ttt
ttt
Old Apr 22, 2008 | 09:15 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If you didn't have the turbo specced with an inconnel arm on the wastegate, then nine times out of ten, it is this that has twisted. What happens is the wastegate arm gets that hot, that the spring tension on the actuator is sufficient to twist it. This has the same effect of backing off the acuator, and thus you lose boost. If it is this, you will have to keep adjusting the actuator to rectify it until you finally run out of adjustment. The only cure is to send the turbo away to have the arm replaced with an inconnel item that can take the heat of high speed running.
Old Apr 22, 2008 | 09:35 AM
capri280's Avatar
capri280
Default car
Thanks mike that explains it clear
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
