XR2i - unsolvable problem?! Please help
Old Apr 20, 2008 | 10:41 PM
riot's Avatar
riot
Post XR2i - unsolvable problem?! Please help
I have a XR2i G reg - engine runs perfectly from cold start but once the engine is warm & you try to start it up -it stalls as soon as you take your foot of the gas & the revs are all over the place up & down? Local mechanic's are totally puzzled - they have changed the cold start, the temp sensor, fuel line & all the electronic diagnostic's are coming up clear. They have no clue what is causing the problem - can anyone here help?
Old Apr 21, 2008 | 06:32 AM
They must be bloody crap then, find a DECENT garage.
I would look at the idle CO, when hot as a first thing, also look for air leaks.
Old Apr 21, 2008 | 06:44 AM
Aaroncast's Avatar
Aaroncast
way wont you (if you correct!!) name and shame these garages!!!!!!!!-
-START >>>>>>((IN MY OWN OPINION/AND WITHOUT PREDJUDICE)))>>>>> AND MAKE SURE YOUR FACTS ARE CORRECT,(VERY IMPORTANT),
IM AMAZED AT THE AMOUNT OF MONEY SPENT IN GARAGES £10000000'S THEN TO COME ON HERE TO SORT IT OUT!!!!!!!!!!!, (IVE GOT IT HOME AND IT WONT RUN RIGHT!!)
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Andypandy260
Sep 23, 2015 10:28 PM
