YB engine stalling when hot ?
Old Apr 20, 2008 | 08:29 PM
Daxcossie's Avatar
Daxcossie
Default YB engine stalling when hot ?
My car decided to stall tonight for no reason whilst sat at a longish idle and would not start again (Car was turning over, but would not start). Left to cool down for approx 10 minutes and it started ?
Then, while running I lost power and had to pull over to the side of the road and called the RAC.
I had left it 15 mins or so and tried it again and it started ?!? Sounded fine, so decided to drive it home slowly and it made it.
Coolant / oil / charge temps were all fine and rad fan is working etc.
I am unaware of heat related stalling issues, are there any ?
How can I get a fuel pump checked ? I am running a Bosch 044 and its noisey as heck all of the time, is this ok ?
Any ideas would be great.
For a start, Im going to check the wiring to the fuel pump and the pump itself.
Old Apr 20, 2008 | 11:23 PM
mikedaf2's Avatar
mikedaf2
if your fuel pump is noisy try changing your fuel filter as this sometimes cases noisy pumps and fuel starvation when they are semi blocked.
Old Apr 21, 2008 | 05:05 AM
stevecossy's Avatar
stevecossy
Could be water temp sensor. Mine had similar thing and after changing all sensors it was the fuel pump not giving enough pressure.
Old Apr 21, 2008 | 06:27 AM
The easiest way might be to wait until it stalls again and see if you have lost spark or fuel ?
Old Apr 21, 2008 | 06:29 AM
Aaroncast's Avatar
Aaroncast
-oh yes!!!!!!!!! expansion/friction!!!!! tightening up!-----but hopefully we wont need to go there!!!!!!.
Old Apr 21, 2008 | 01:04 PM
Daxcossie's Avatar
Daxcossie
Im going to try that tonight.
Does the L8 ECU store fault codes ?
Old Apr 22, 2008 | 07:37 AM
Daxcossie's Avatar
Daxcossie
OK. Well after running for approx 45 minutes at idle last night it cut out again. I tested for a spark 3 times and nothing. Then left it 5 / 10 minutes and then the spark had come back. I could smell fuel aswell, so I guess that rules out the fuel pump and crank sensor.
Starting to think it could be the ignition module........
Old Apr 24, 2008 | 08:19 PM
Daxcossie's Avatar
Daxcossie
My problem turned out to be a female spade not seated correctly in the connection block for the ignition module. Took sleeve off, pushed spade in and it seems to be ok now.
At least Ive got a spare ignition module now......
Old Apr 25, 2008 | 06:57 AM
The intermittant ones are al ways the buggers to find as never there at the time you want them.
Glad you got it fixed, if you need new connectors and suchlike I use polevolt.co.uk
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
dlwarrior
Aug 5, 2015 10:19 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
