speaker maximum moutin depth
Old Apr 19, 2008 | 05:03 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default speaker maximum moutin depth
what is the maximum mounting depth i can have for the front speakers in a series 2?
help would be appreciated
Old Apr 20, 2008 | 03:27 PM
RSandy's Avatar
RSandy
if you keep them fitted behind the standard grilles, your very limited, and can only go for a basic 10cm unit, which will all be very similar in depth
but if your willing to mount them on the outside of the grille, then you can fit up to a 17cm speaker, and the depth is not an issue as you build a spacer ring to suit. i made up a pair of mdf spacer rings, and then trimmed some of the metal on the mounting frame behind the grille to give extra speaker cone clearance
TrevCos
Alloy wheels and ICE for sale
Sep 13, 2015 02:12 PM
hopper350
Sep 4, 2015 12:53 AM
cameron2
Aug 30, 2015 08:15 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
