speaker maximum moutin depth
if you keep them fitted behind the standard grilles, your very limited, and can only go for a basic 10cm unit, which will all be very similar in depth
but if your willing to mount them on the outside of the grille, then you can fit up to a 17cm speaker, and the depth is not an issue as you build a spacer ring to suit. i made up a pair of mdf spacer rings, and then trimmed some of the metal on the mounting frame behind the grille to give extra speaker cone clearance
TrevCos
Alloy wheels and ICE for sale
13-09-2015 02:12 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
