Need help fitting New fuel pump on S2
Old Apr 18, 2008 | 10:33 PM
anvini's Avatar
anvini
Unhappy Need help fitting New fuel pump on S2
Hi mates!!!
I need some help about fitting a new fuel pump on my Escort RS turbo S2 `88
I had buy a new fuel pump on "Autospecialist", here is a pic:
But the problem is that I can´t bolt on the out of new fuel pump with a plug of the older fuel pump, I don´t know what it is, maybe a pressure valve or something?? Here´s a pic:
Maybe the older fuel pump not is the original one for Rst S2 so the new does not fit??
What will I need to fit the new one??
I´ll be waiting for answers..............
Thanks
Old Apr 19, 2008 | 05:13 PM
denbo's Avatar
denbo
Hi i need new one aswell but their is no block off value like that on my pump . Why do u need new one like mate ? Am going to put new one due to the 2nd fuel pump relay has gone .
Old Apr 19, 2008 | 05:22 PM
Dragsteer's Avatar
Dragsteer
If you cannot put screw from fuel pipe to new pump, put another pipe with right screw on it so then can put it. I dont see another way to do it.
denbo: on my rst doesnt have so big cap on screw.
Old Apr 19, 2008 | 05:50 PM
anvini's Avatar
anvini
Hi Denbo and Dragsteer
Thanks for your post.
I think, not really sure, that my older fuel pump is from other type car other Ford Escort, not a original Escort Rs turbo S2, so you don´t have so big cap on screw.
Looking on Ebay I saw this:
M12 banjo union (8mm pipe tail)
M12 dome nut
2x copper washers
Maybe with this I will fit my new fuel pump?????
CheeRS
Old Apr 19, 2008 | 08:45 PM
rs_turbo_ant's Avatar
rs_turbo_ant
i just fitted my new one right pain in the arse it was kept blowing the fuse.....and after messing about for million hours ma car wouldnt fire up
Old Apr 19, 2008 | 10:54 PM
Dragsteer's Avatar
Dragsteer
what you do... isnt so hard. just watch to dont mess + and -.
anvini: yes, this things on picture I have.
so just dont forget to dissconect battery +, and watch for + and - on pump.
Old Apr 19, 2008 | 11:18 PM
anvini's Avatar
anvini
Ok!! Dragsteer
Definitely I think that fuel pump is not the original for Rst S2, maybe for another Ford Escort but not a turbo Rs S2.
I would like to know it. And the best thing is that my car has worked with this rare pump installed.
Old Apr 20, 2008 | 11:39 AM
Dragsteer's Avatar
Dragsteer
I have same situation , when I bought car , it has some bmw pump on it. And work ok, but I have problems with start hot engine. how with original rst pupm is ok. good luck
Old Apr 20, 2008 | 02:33 PM
anvini's Avatar
anvini
I´m going to replace the fuel pump due some running problems that maybe caused by pump but not sure mate!!
Same like you.
Now I know the type of fuel pump i´ve got fitted, a friend of "rsownersclub.co.uk" Lukeduke told me that:
"My microcat says its a fuel pressure regulator for 1.6 cvh EFI (D/GB) FOR CATALYST WITH LAMBDA CONTROL. hope that helps"
So it is a incorrect fuel pump for my car, it is for EFI CVH and Rst S2 is MFI WITHOUT CATALYST.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
3doorcozmess
Aug 21, 2015 11:17 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
