Xr2 No spark
Old Apr 12, 2008 | 09:00 PM
mikeyrsturbo123's Avatar
mikeyrsturbo123
Wink Xr2 No spark
Hi i have a 1989 Fiesta Xr2, The problem is it wouldnt start so went through the usuals fuel spark etc to find i have no spark.
When i put a multimeter across the coil with the ignition turned on there is no voltage is this correct?
Anyone got any suggestions as to what it could be and any ways of testing various components to eliminate them Thanks in advance
Old Apr 12, 2008 | 09:09 PM
mechanic28's Avatar
mechanic28
that will be 90% your dizzy amp playing chap
Old Apr 12, 2008 | 09:12 PM
mikeyrsturbo123
you mean the 3 pin bit on top of the distributor?
Old Apr 12, 2008 | 09:15 PM
mechanic28's Avatar
mechanic28
yer the little black box thing!!that is of course if u aint got a immobiliser fault
Old Apr 12, 2008 | 09:17 PM
mikeyrsturbo123
Deffo not immobiliser fault as i havent got one lol. Would the ignition amp module stop me having voltage at the coil?
Old Apr 12, 2008 | 09:37 PM
mechanic28's Avatar
mechanic28
pretty sure it controls all that!common for these to go down fella!might be worth of course trying the simple things i.e rotor arm cap etc first!
Old Apr 12, 2008 | 09:46 PM
mikeyrsturbo123
Wink
Yeah i tried rotor arm cap etc. I will get a distributor tomorrow and try it thanks.
Old Apr 13, 2008 | 02:01 PM
mikeyrsturbo123
Legend cheeRs for that its now got a spark!!!!
Old Apr 13, 2008 | 08:06 PM
mechanic28's Avatar
mechanic28
no probs fella pleased it sorted and all ok
Old Apr 13, 2008 | 10:03 PM
stage 3 muppet's Avatar
stage 3 muppet
why not post up the cure to the problem so others can see what it was if using the search facility
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
deathrider666
Sep 28, 2015 06:12 PM
mondeomark
Sep 28, 2015 06:28 AM
pabloXR
Sep 21, 2015 12:42 PM
